CM12 for the HD
78 replies to this topic
#1 nal
nal
  • 164 posts
  • LocationIllinois
  • Current Device(s):Droid Razr HD xt907/26, LG G2, Nexus 7 2012
Posted 14 November 2014 - 09:39 PM
welp, looks like its that time again :)
  • rico likes this
#2 CWM8012
CWM8012
  • 25 posts
  • Current Device(s):Xt907
Posted 15 November 2014 - 10:28 AM
Is this android l?!?!
#3 nal
nal
  • 164 posts
  • LocationIllinois
Posted 15 November 2014 - 03:30 PM
yes, lollipop
#4 CWM8012
CWM8012
  • 25 posts
Posted 15 November 2014 - 08:58 PM
Sweet, it's running pretty smooth! :p Do you know how to turn off the notification light when charging?
#5 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
  • Google+:Ivan Samuelson
  • LocationColumbus, Ohio
Posted 16 November 2014 - 05:00 AM
I have been wondering the same thing.
Also, blue-tooth is wonky. When I attempt to play music through it, it skips, jumps and it plays the music slower than it should (you know, like taking an old 45 rpm record and playing it on 33-1/2 speed for us old-timers out there).
Google Play Movies and Netflix also refuse to work. dHacker told me on Twitter it's due to DRM which he is still trying to figure out. I noticed in the error log that's what is what saying, so if you use Google Play movies or Netflix with your phone, be forewarned it doesn't work. No biggie for me. I have my Nexus 7 running Lollipop and it works fine which makes sense since that is an official Google release of Lollipop.
Still, nice to know dHacker released this for the xt926.
And other than the blue-tooth, Google Play Movies, and Netflix issues, the ROM is pretty stable. Battery life isn't as great as it is under CM11, but I can still get a days worth out of my phone. But, since this is the initial release, it's performing FAR better than what you would expect. DHacker did a great job on this initial release.
  • rico likes this
#6 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
Posted 16 November 2014 - 05:57 AM
Dhacker released an 11/15 release - downloading now.
Get it here:
Also, updated Lollipop GAPPS:
  • rico likes this
#7 Playb3yond
Playb3yond
  • 75 posts
Posted 16 November 2014 - 07:55 AM
Installed! This is still another stable release. It literally runs like water. I'm in awe. Still can't run real racing 3, fruit ninja and 8 ball pool play without a problem
#8 nal
nal
  • 164 posts
  • LocationIllinois
Posted 16 November 2014 - 08:54 AM
Get it here:
can we just flash over this or do we need to wipe?
huge fan of the new headset connected thing, my razr hd has problems where my earbuds disconnect and now I can see when it is, so now I don't need to worry about it blaring music through speakers
its great, runs good so far
#9 RikRong
RikRong
    Cap'n Slow
  • 2,116 posts
  • Twitter:@rlongjr80
  • Current Device(s):Moto X Pure 2015 / N7 2013 / RazrM
Posted 16 November 2014 - 09:12 AM
It's a whole new base, I would flash clean.
Sent from my HTC6525LVW using Tapatalk
R. Long: Nexus 5 on Carbon / Slimmed N7 2013 / RazrM stock KK
#10 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
Posted 16 November 2014 - 11:53 AM
If you already put on his 11/14 Lollipop release, then you can just dirty flash over it.
If, however, you are CM11, then yes, a clean flash is needed. Just do the norm: wipe data, system cache and dalvik.
On another note, what exactly does "wipe dalvik" do for us now on Lollipop since it's ART? ;)
#11 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
Posted 16 November 2014 - 04:29 PM
Wow. DHacker has released another image for 11/16. Get it here:
#12 nal
nal
  • 164 posts
  • LocationIllinois
Posted 16 November 2014 - 06:59 PM
I'm really glad Dhacker is supporting this device!
when I wiped Dalvik it did the Android is upgrading thing lol.
#13 Not_A_Dev
Not_A_Dev
  • 66 posts
  • Current Device(s):Motorola Droid Razr HD Maxx
Posted 16 November 2014 - 08:26 PM
Can't get ES File Explorer to receive root privileges in supersu. Other apps that need root can get root. Anyone else running into this issue?
Edit: running dhacker's CM 12 build from 11-16-14
#14 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
Posted 16 November 2014 - 09:12 PM
Under Lollipop, getting write access to system is only possible if you boot into recovery. That, or file explorers with root access have to be updated correctly.
But I do remember Chainfire stating that root access to system would be harder, if not impossible without booting into recovery.
It's a security thing. Trying to make Android more secure.
  • grnsl2 likes this
#15 Not_A_Dev
Not_A_Dev
  • 66 posts
Posted 17 November 2014 - 05:31 AM
Under Lollipop, getting write access to system is only possible if you boot into recovery. That, or file explorers with root access have to be updated correctly. But I do remember Chainfire stating that root access to system would be harder, if not impossible without booting into recovery. It's a security thing. Trying to make Android more secure. Sent from my DROID RAZR HD using Tapatalk
Over on xda, I found
, but I'm a little hesitant to flash this patch, because the OP has intended it to be used on the N5 originally, and isn't sure if it works for other devices. But apparently it fixes the root issue for a bunch of apps on Lollipop, including ES File Explorer.
#16 Not_A_Dev
Not_A_Dev
  • 66 posts
Posted 18 November 2014 - 06:24 AM
And just like that, an updated version of ES File Explorer pops up in Play Store that works with Android 5.0 and enables root privileges :)
#17 7eregrine
7eregrine
  • 163 posts
Posted 19 November 2014 - 01:03 PM
Might have to try this. Any more comments on how it's running?
#18 nal
nal
  • 164 posts
  • LocationIllinois
Posted 19 November 2014 - 02:47 PM
Using it right now, celluar data drops randomly for me. In the newer nightlies there is a "clear recents" stuck at the bottom, which will probably be fixed. The DRM Issues has been fixed in the latest nightly though.
edit: moved to latest nightly and the issue with the clear recents is fixed, just transparency is broke
#19 jlang11
jlang11
  • 29 posts
  • LocationFL
  • Current Device(s):RAZR HD MAXX
Posted 19 November 2014 - 05:01 PM
What BL do we need o install this? Can we be on JB, or do we need to be on KK??
#20 Playb3yond
Playb3yond
  • 75 posts
Posted 19 November 2014 - 07:17 PM
KitKat
