Different Kernel.
Even though it boots and everything?!
Posted 19 March 2013 - 06:31 PM
Different Kernel.
Posted 19 March 2013 - 06:33 PM
Posted 19 March 2013 - 06:37 PM
I thought you said it gives you a black screen??
Posted 19 March 2013 - 06:39 PM
I said they a do, except one. The one that boots and functions will work for a day or two then it will go black and I can press the wake/sleep button and the buttons light up and all, but if I reboot it, it doesn't work. So, I have to reflash.
Posted 19 March 2013 - 06:43 PM
Uhhh... That's weird. I assume if it boots it's for the .8 Kernel. But the failing after a few days is quite strange. Have not heard of that happening before.
Posted 19 March 2013 - 06:53 PM
It was updated after the .16 release if that helps.
Posted 19 March 2013 - 07:03 PM
yeah, I'm on stock JB right now. I was using Hash's most recent kexec-cm10.1 and it works great. But, eventually crashes.What Rom are we talking about??
Can you boot into anything right now??
I thinking you should use the Utility and start fresh on JB. I know you did that already with ICS earlier but it may help your issues.
