Safestrap Recovery v3.05.2 not finding SD
safestrap ROM sdcard
10 replies to this topic
#1 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 21 December 2012 - 08:15 AM
So I'm flashing various ROMs on my Razr M with Safestrap. However, everything is being written to internal memory and not my using my SD at all. It won't find anything on my SD (like a ROM zip or ANY of the folders). Even when I go into the file manager in Safestrap, it shows nothing on my SD. Bad download?
#2 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 21 December 2012 - 09:15 AM
dont go to folder named /sd card... need to find the one named /external sd or go into storage/storage01 to find your .zip; and it is yet not possible flashing to external sd
#3 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 21 December 2012 - 09:17 AM
This is even with stock ROM slected.
From the RAZR M
#4 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 21 December 2012 - 09:18 AM
X
#5 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 21 December 2012 - 09:30 AM
I am going to storage-> sdcard01 and nothing is showing up. I can find all the stuff if I use Jrummy's root browser. I think I must have a bad download. I will use my computer to download it this time and reinstall it.
Thanks for clearing that fact I can't use the sdcard to flash yet. Thank you.
From the RAZR M
#6 priddyma
priddyma
  • 114 posts
  • LocationDeKalb, IL
  • Current Device(s):HTC One XL, Motorola DROID RAZR
Posted 21 December 2012 - 10:05 AM
From the RAZR M
sdcard0/sdcard01 Are how jellybean sets up the new users I believe.
You want to look for /mnt/sd-ext/ or sdcard-ext something similar ( as long as moto hasn't changed how they name/mount sd cards.
DROID RAZR XT912 Batakang JB | Samsung Galaxy SIII Pebble Blue - On the way!
#7 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 21 December 2012 - 11:19 AM
So this is what it looks like when I go into the Root Exploder of ROM Toolbox.
Sdcard= internal storage
ss= internal storage
sdcard0= internal storage
sdcard1= sdcard
The only folder SS that shows any contents is sdcard.
From the RAZR M
#8 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 21 December 2012 - 11:28 AM
yes it is not yet possible to flash on stock rom you have to create a romslot1 and flash there... my advise to you is do a factory reset and have the stock rom as empty as possible saves ram and space.. and flash whatever you want in romslot1 with 1GB. until hashcode work out the bugs or whatever is preventing us to flash in stock partition. and based on your pic.. you removable sd card is the one in /sorage/sdcard1 and that is where your backups will be.
#9 jvasquezhhi
jvasquezhhi
    Frankensteiner
  • 330 posts
Posted 21 December 2012 - 11:33 AM
and if you trying to plug phone into computer to get access to your thing like pictures and such. it works better if you set your phone to debugging mode
#10 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 21 December 2012 - 12:42 PM
Thank you all so much for your help.
I'm not trying to flash stock, but would like to use more than one slot in SS. So because the RAZR M only has 8 GB internal memory (before formatting) and all the data from flashing a ROM to slot one being on the internal memory, there is not enough left to create slot 2 let along flash a ROM in that position.
I can access my sdcard on the computer and in root browser but it is not accessible in SS. I downloaded SS straight to my phone and didn't check MD5 (I know, my bad). In the SS thread here in the RAZR M section, it says that that bug (not being able to access the sdcard if any ROM slot but stock) was fixed in the latest release. I know that is the one installed, and I'm not even able to access my sdcard in SS with the stock ROM as active.
I will do a factory reset and leave stock as empty and possible. I will also redownload SS and check MD5.
From the RAZR M
#11 hillmom
hillmom
  • 131 posts
  • Twitter:whillmom
  • LocationIdaho
Posted 23 December 2012 - 08:48 PM
Went back to stock removed SS and reinstalled with a MD5SUM confirmed version and I'm able to access SDcard where the zips are.
Thanks again for all your help.
From the RAZR M
Also tagged with one or more of these keywords: safestrap, ROM, sdcard
