Posted 01 January 2013 - 06:03 PM
Posted 01 January 2013 - 07:11 PM
haha great, thank you i just wanted to look around in there, and im sure others are curious too.
I wanna find out what the Code is for 02 AKEY, anyone know what it is? Does not seem to allow (*) or (#) and all the regular codes I've tried do not work.
Posted 03 January 2013 - 06:31 PM
not sure sorry. What does that do though?
Well, I am not exactly 110% sure what it does, however what I believe it does is it is a series of #'s 0-9 that is 18 digits long. First off Motorola does not state that they participate with the AKEY, which I find hard to believe. But getting back to and maybe this is my theory is the AKEY is the Key to Unlocking the Razr HD, through the keypad. Which I'm still looking everywhere for the AKEY for our device which it must exist. Sure it is a Motorola device, but at the same time it using Verizon's system and an 02 AKEY is part of that makeup. After further research the AKEY is an Authorization Key, that is those 18 digits must be and this is an assumption used to activate a phone. Now here is the part that I am trying to understand and it sounds conclusive through several cdma forum's of course focused on research of iphones, but I don't so much think it matters whether it is an iphone, an android or whatever, because it comes down to codes entered into Verizon system. So, here is what I found and maybe this hack can work to Unlock the phone, as Unlocking phone is the end result of the combination of the ESN easily found in Settings that is 8 digits, with the AKEY that represents 18 digits, there is however an order as I have found and read. Here is the Hack , I've tried variations which the ESN is clean, however it is missing AKEY. This 26 digit code must do something amazing. Please, let me know if you find out.
Edited by KaChow, 03 January 2013 - 08:08 PM.
- exsquid likes this
Posted 24 February 2014 - 03:12 PM
I've read a few of your posts on other forums. Did you ever get anywhere with this?
Posted 24 February 2014 - 03:25 PM
Sent From My DEV X
Sig by
Also tagged with one or more of these keywords: program
Legacy Devices →
VZW Droid Razr Help [XT912] →
Fastboot Low Battery, No Factory Cable NeededStarted by Guest_BDH_* , 01 Apr 2012 fastboot, low, battery, factory and 4 more... |
