[Guide] Installing 6.12.175.xt912
37 replies to this topic
#21 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
  • LocationSchaumburg, IL
Posted 13 February 2012 - 02:25 PM
I was running 175 yesterday but for me, I had at least 3 or 4 random data drops while on cdma only. I personally have not had a single drop on 173 or even 174 when I was on that leak. Back to 173 for me.
I was having another issue with 175 and thought it was an error in the build but now that I am back on 173 I realize it still does not work so it may just be my phone.
Except um, the LTE radio is identical in all 3 builds... Just sayin.
#22 JungleKing76
JungleKing76
  • 446 posts
Posted 13 February 2012 - 02:43 PM
Yes but as my post said, I was on CDMA only and that radio was changed in 175. I am currently in a 3g only area. There may not be any known reason but that was my personal experience. 175 caused several data drops that I just could not stay on it. I have never had a data drop in 173 or 174.Just reporting the issue in case others have it too .
#23 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 13 February 2012 - 03:12 PM
Ah, totally missed that. My bad.
#24 JungleKing76
JungleKing76
  • 446 posts
Posted 13 February 2012 - 04:07 PM
No worries. I figured as much.
#25 snives
snives
  • 947 posts
Posted 13 February 2012 - 05:00 PM
Running this with DT's Go Faster tweaks (updated the build.prop for 175), and it is running smooth so far.
#26 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
  • Twitter:@droidth3ory
  • LocationTroy, Michigan
Posted 13 February 2012 - 05:43 PM
If you swapped the props out, at the bottom of mine you will notice a section named #Go Faster. Copy that on the prop you're using. :) That's the good stuff.
  • mattlgroff likes this
#27 timdog68
timdog68
  • 34 posts
Posted 14 February 2012 - 07:40 AM
just upgraded but I'm noticing really bad results on 3g speedtest.net.
Like 0.62 mps bad not sure if this is related to .175 or not but just happened to notice it after the upgrade
Well I downgraded via the windows utilty to .748 and upgraded back to .173 and still $#!+ty 3g speeds so its not the .175 upgrades fault.
Edited by timdog68, 14 February 2012 - 08:41 AM.
#28 larrygeary
larrygeary
  • 160 posts
  • LocationNJ, USA
Posted 14 February 2012 - 08:22 AM
Snives, could you check something for me?
1) Power off your phone.
2) Plug in the charger and start charging from a wall socket.
3) Let me know if you see the charging LED.
We had the charging LED when the phone was OFF and charging in 744 and 748, but the 173 update broke it. I'd like to know if 175 fixes it.
Thanks.
#29 DroidTh3ory
DroidTh3ory
    Developer
  • 648 posts
Posted 14 February 2012 - 08:32 AM
Thanks.
173 straight from VZW... Charging light is fine as is the Search function in the app drawer. Just saying. Fast booted to. 748 installed the OTA from Check Updates.
f%$kin around with those leaks. Lol
#30 larrygeary
larrygeary
  • 160 posts
  • LocationNJ, USA
Posted 14 February 2012 - 10:07 AM
I also have 173 straight from Verizon, and the charging light is not fine. It's gone. I've never flashed any leaked ROMs. Several people on the Motorola forum report the same problem with 173 as I've experienced.
#31 JimmyInTheROC
JimmyInTheROC
  • 72 posts
Posted 14 February 2012 - 11:12 AM
Can't restore root after .175.
I flashed back to .748, OTA'd to .173, then rooted using the Droid Razr Utility 1.3. Used Voodoo OTA RootKeeper to backup root. Installed .175. Now when I click "Restore root" in RootKeeper, it says that "root su restored" but nothing actually happens. The check-boxes don't check and my root-necessary apps will not run.
Any ideas?
Went back to the Razr Utility, realized motofail is for all 2.3.6. BOOM!
Edited by JimmyInTheROC, 14 February 2012 - 11:40 AM.
#32 JungleKing76
JungleKing76
  • 446 posts
Posted 14 February 2012 - 03:18 PM
Any ideas?
Never mind...just realized you edited and figured it out....
#33 JungleKing76
JungleKing76
  • 446 posts
Posted 14 February 2012 - 06:46 PM
Interesting...my charge light does not work but the search button in app drawer does now. Last week after ota search did not work but today I had to fastboot back to 748 and ota again and now search in app drawer does work.
#34 bikercr
bikercr
  • 12 posts
Posted 15 February 2012 - 06:27 AM
Now on 175--everything works fine including 3g and transitions to/from 4g. Search button crash is fixed. Charge light, however, is off. I didn't check this on 173 but I know it worked on 748.
#35 larrygeary
larrygeary
  • 160 posts
  • LocationNJ, USA
Posted 15 February 2012 - 06:59 AM
There is a 176 out now. I think we'll see a few more of these incremental unofficial releases before the next OTA as we all report bugs in 173. I've been doing that on the Moto forum, as have others.
#36 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 15 February 2012 - 04:42 PM
I wouldn't report bugs for an unreleased OS to Moto directly.
#37 DonDraper
DonDraper
  • 156 posts
  • LocationLexington, SC
Posted 16 February 2012 - 01:11 PM
If you don't load the update for google search, it will not FC on 173. Have you not updated google search to the available market update? I'm pretty sure the FC even happens BEFORE 173 is installed with this update.
#38 jeeprider8
jeeprider8
  • Twitter:geigerjj
Posted 17 February 2012 - 08:45 PM
I can't get this to install, was pretty much stock, but have rsd'd twice and done the two ota's to 173, then tried again, still no-go.
Trying to install dhackers latest ics, which says 17x, but it won't boot for me on 173, thought I'd try 175, but can't make it happen. I factory reset, Rsd, skip all setup, ota 2x to 173, then try to instal via recovery per the instructions. Previous ics by dhackers have ran fine via safe strap, but the last few 17x ones won't. HELP!!
Thanks to all!
