Post your PC set ups
#101
Posted 17 February 2013 - 11:09 AM
What percent 40 or concentrate? Its endless....
Sent from my DROID RAZR MAXX using Tapatalk2
#102
Posted 17 February 2013 - 02:08 PM
Only after you're assured pf actually having components can you decide on the medium, b/c the system may have restrictions of its own that we'll need to take into consideration.
Sent from my Infinity using Tt HD
#103
Posted 17 February 2013 - 02:11 PM
Those would be tested to find the optimum combination(s) to run the system at - the first an foremost part is the system itself. Need comp/evap system small enough to fit inside a case (optimally) or, if not, then at least reside outside (not optimal - too much chance to break tubing).
Yea wonder if you can even find something so small..
#104
Posted 17 February 2013 - 04:16 PM
It would take a 4cu mini fridge, and a 6-10 gal tank, and a massive radiator, prob a dual 200mm to sit inside the fridge. Set to your temp you feel comfortable running, and it would keep the CPU (first on loop) about 5 degrees above the fluid. The loop should go CPU, gpu(full block), split to parallel one dram only, other NB followed by CPU vrm's. The case would have sealing quick couplings for ease of transport/ maintenance.
To do something with refrigeration directly on CPU OR GPU. would require some serious engineering AND prototypes. I wouldn't be surprises if development cost upwards of 10k. If a compressor could even be made to fit in a case. Second problem. Voltage disturbance cause by the compressor. Third cost of the finished product. 4th no matter how you think you could chill two components due to the nature of freon and EPA laws on handling it. You'd need a sealed system specifically for that one component. A setup for a 670 gpu could never be adapted to a different card.
John, condenser coil size in not an issue, those mini fridges I referred to, don't even have fans on condenser coil. The tubes are just open to the air. A walk in cooler in a restaurant only has one about 14"x14" with fan. The compressor is the only set back
Sent from my DROID BIONIC
- johnlgalt likes this
#105
Posted 17 February 2013 - 04:32 PM
27.43KB 33 downloads
Sent from my TARDIS
- Redalert likes this
#106
Posted 17 February 2013 - 04:46 PM
Just cleaned up. It may not be the fastest, and it may only have one monitor, but it's mine and I love it
Sent from my TARDIS
Nice... very clean..
- rockaholic112 likes this
#107
Posted 18 February 2013 - 05:46 AM
- rockaholic112 and Redalert like this
#108
Posted 18 February 2013 - 06:03 PM
Core i5 2600k @4.00 GHz
8gb (4x2gb) gskill ripjaws DDR3
GTX 660ti super clock 2gb
All wrapped in a CM Storm Scout. Damn good case for $80.
Humble, yet I can play BF3 almost maxed, Skyrim maxed, blah blah blah.
Picture time!
57.19KB 26 downloads
63.3KB 26 downloads
#109
Posted 18 February 2013 - 09:27 PM
Once I get it configured again I'll post my OC numbers
#110
Posted 19 February 2013 - 05:02 AM
50.56KB 25 downloads 37.25KB 25 downloads
Now that's purdy..
#111
Posted 20 February 2013 - 08:20 AM
So, hey all!
Temp sig by livininginkaos
#112
Posted 20 February 2013 - 10:15 AM
#113
Posted 20 February 2013 - 08:09 PM
Soocold told me to get my butt over here.
So, hey all!
Hi
#114
Posted 20 February 2013 - 08:10 PM
Still fine tuning my dram, but BCLK 101.3 on a second gen i7 that normally freaks after you go over 100.3
Ur messing with voltage right? If so where are u at?
#115
Posted 20 February 2013 - 09:24 PM
#116
Posted 21 February 2013 - 05:27 AM
#117
Posted 21 February 2013 - 05:51 AM
#118
Posted 21 February 2013 - 08:32 PM
Um 4.95GHz 1.5v bclk 101 now and dram is at 2154 CL 8-9-10-20 2n 1.8v and an rear end load of other finer tweaks to hidden clocks/timings that I don't have the patience to post
Ah nice
#119
Posted 22 February 2013 - 05:02 AM
#120
Posted 22 February 2013 - 07:36 AM
