Hi all,
My XT910 gave plenty of problems with the VFAT partition of the SD card. This was back in the gingerbread days. Recently I took the time to dig through the OTA to see why it would not install and now I'm over on ICS. phwew! In the hope that the corruption problems would be solved under ICS I gave the sd card another try, but knowing how frustrating vfat can be, I tried ext3. Unfortunately it doesn't look promising. I got "unsupported filesystem". Can anyone enlighten me on the alternatives to use a decent filesystem? I hope the solution is out there... ext2 would even do, but journalling would be a nice extra.
alternative SD card filesystems
NTwoO
, Feb 03 2013 09:12 AM
vfat xfs ext2 ext3 ext4 journalling file system sd card
No replies to this topic
Also tagged with one or more of these keywords: vfat, xfs, ext2, ext3, ext4, journalling, file system, sd card
Legacy Devices →
VZW Droid Razr General [XT912] - {Q&A, Discussion} →
SD card is using a partition instead of the SD cardStarted by reese , 18 Mar 2013 sd card |
Legacy Devices →
VZW Droid Razr Help [XT912] →
Oops - Inserted Sd Card During Boot, Now Needs FormatStarted by JJT211 , 23 Aug 2012 sd card, format |
Legacy Devices →
Sd CardStarted by Steven Vaccaro , 10 Feb 2012 SD Card |
DroidRzr.com →
Droid Razr Apps, Games and Accessories →
Undelete AppStarted by augie757 , 29 Nov 2011 Life Saver oops, SD Card |
