Worked perfectly on stock jelly bean! Thanks!
Mike
Your Welcome!
Posted 11 February 2013 - 09:58 AM
Mike
Posted 11 February 2013 - 08:19 PM
Posted 11 February 2013 - 08:35 PM
GREAT !! I dont have to waste my time with roms and third party apps. Just what I needed.
Kind of tired of trying roms, just want simple upgrades.
Thanks OP
Posted 11 February 2013 - 08:44 PM
Posted 12 February 2013 - 05:45 PM
Tried to do this to the stock side, and it failed. It seems like every app that starts, gets the 'stopped unexpectedly' error. Good thing I made a backup!I wouldn't recommend flashing to the stock slot I think the update scripts have to be made different. This mod is made for flashing in the non stock slots. If you want this mod on the stock side then I would extract the zip then copy over the services.jar and service.odex to the framework folder then set permissions to rw-r-r then reboot into safestrap wipe cache and dalvik. Then repeat the process for the systemui apk and odex, if you try to copy them both at the same time it might crash.
Posted 12 February 2013 - 06:04 PM
Thanks OP
Posted 12 February 2013 - 07:41 PM
I really want this mod, (the batt portion), on my stock side...
Edit: Spoke too soon. Restored my nandroid backup, and when my phone boots, the red M, and then no video. I can hear the boot sound, etc. Booted into recovery, wiped cache and Dalvic cache, rebooted, still no video. If I boot to Slot 1, where Fuzion is, all is well. I really want my stock side back, with all of my installed apps... WAHHHH!. Oh well, unless someone has a good suggestion, I will just reflash the stock JB back to that side...
Posted 12 February 2013 - 07:45 PM
Dang that sucks I think stock flashing and restoring is still buggy with safestrap 3.11 that's why I always use slots and don't touch my stock side.
Posted 12 February 2013 - 08:01 PM
I didn't flash it, I tried to copy the servies.jar and services.odex files. I made backups of the stock ones, then copied the new ones into the folder, rebooted, and blank screen.
Posted 12 February 2013 - 08:05 PM
No, but if you don't mind giving me the directions, I can try. I have used ADB before, but am not real fluent with it. I took the original files and renamed them to .orig, like services.jar.orig.Oh sorry misread your post, I will remove that option from the OP framework files are temper mental and normally needs to flashed. Have you tried to connect via adb on stock side if you had it enabled and correct the permissions or push original files back?
Posted 13 February 2013 - 04:01 AM
When you said 'set the permissions', all I did was mount the folder read/write, then unmount it when I was done. Is that where I screwed up?
I would appreciate the help...
Posted 13 February 2013 - 07:41 AM
Posted 13 February 2013 - 08:31 AM
Thanks a ton for your willingness to help. Last night I was poking around in there with ADB and could not find the original files. That is when I remembered the part where I 'restored a nandroid backup'. After the restore is when the screen when dark. I don't think those files are the culprits any longer. I appreciate the offer of making a script, though, but I don't think it will help.
On a positive note, now that I am running on Slot 1, your mod works GREAT!
Posted 09 March 2013 - 10:41 PM
Posted 09 March 2013 - 10:52 PM
Any chance of you re-doing these files for the new JB OTA release? I loved the odexed version on the JB Christmas leak but unfortunately it doesn't work on the OTA. It will hose your phone if you try it on the new OTA. I know, I tried....
Hope you'll do it!
Thanks,
Mike
Posted 09 March 2013 - 11:10 PM
Hope you'll do it!
Thanks,
Mike
Posted 10 March 2013 - 02:55 PM
Nevermind lol. I'll be working on this tomorrow.
Posted 10 March 2013 - 05:41 PM
Hope you'll do it!
Thanks,
Mike
Posted 11 March 2013 - 12:58 PM
Posted 11 March 2013 - 07:41 PM
