Did I Brick It?
Posted 16 February 2012 - 04:24 PM
New guy here. Um... lol. I was trying to flash Infex. I forgot to unzip the file and placed the zipped file on my ext card. I noticed this after I had already wiped the dalvik, cache, and formatted the system. I went to reboot so i could put the unzipped file on my card, and now I'm stuck on the Dual Core screen... It's been sitting there for 10 minutes now... I guess I f%$ked up. >< CRAP!!!! Any advice/help would be so much appreciated by you guys.
Many, many thanks in advance.
-Dan
Posted 16 February 2012 - 04:30 PM
Posted 16 February 2012 - 04:32 PM
Posted 16 February 2012 - 04:34 PM
Posted 16 February 2012 - 04:35 PM
Sent from my ROOTED SAFE STRAPPED RAZR SHARP RAZR MAXX ROCKIN ECLIPSE FRANKENSTEIN AND A SUPER LONG SIGNATURE
- mattlgroff likes this
Posted 16 February 2012 - 04:38 PM
Posted 16 February 2012 - 04:42 PM
Posted 16 February 2012 - 04:43 PM
Installation aborted
look under the development forums. Can't miss it. If you can charge the phone, charge it first. Then run the firstoption on the utility. I believe its the one to fastboot to.748Thanks Joel. But, I did put the zip file on my ext card. I didn't see it when I went into bootstrap, so I thought I needed to extract it. hmmmm... Where can I find Matts Utility?
Posted 16 February 2012 - 04:44 PM
Posted 16 February 2012 - 04:53 PM
Posted 16 February 2012 - 05:00 PM
Good luck
Posted 16 February 2012 - 05:05 PM
Posted 16 February 2012 - 05:06 PM
Posted 16 February 2012 - 05:46 PM
I ran the utility. what is the normal time to reboot the device??? Everything seemed to work just fine. Just curious.. I let it sit for 5.. was still at the Dual Core screen..
Posted 16 February 2012 - 05:47 PM
Posted 16 February 2012 - 05:51 PM
Posted 16 February 2012 - 06:14 PM
Posted 16 February 2012 - 06:49 PM
