[Mod] Inverted Gapps For Moto Ics Leak Roms Only ( Updated 7-7-12 )
Posted 08 June 2012 - 05:02 AM
That said credit for this work goes to Travp624. He is the one who made and put things together up front. I only took his Inverted *.apk files out of his ZIP files and redid them so we can use them on the Motos while using SafeStrap. In getting approval from Travp624 he requested any specific issue or problem with an APP itself please post details over in his Inverted thread at RootzWiki ( ). When doing so please state in your post that you are using it on a Moto with SafeStrap or what not so he knows that up front. His posted files in that thread are specifically for the Gnex and not our Motos, and those files will fail on installing when using Safestrap. So everyone knows as I discussed with Travp624 when he updates his work I will update these files so they stay current on both end. He is to busy to deal with both right now so I will work with him on keeping our stuff updated as he updates.
So now lets get on to the good stuff. As you will notice there is 2 different setups depending on the App you want to use Inverted. Some are flashable ZIP files and the others are just Inverted apps signed so they can just be clicked on and installed directly on the device without having to mess with SafeStrap. I also made each part on its own, but you will also see I made a All in One flashable ZIP of the 6 different Inverted apps. This way if you use all of them you only need to flash one thing. If you only use specific things you can just download the ZIP files for what you want a use those
DroidRazr, myself, Travp624 accept No respondsibility for your device if you use these. You are doing so at your own risk.
Install instructions
1: Download the files you want or need that are posted below. Place them on your sdcard in a place you know they are at for installing
2: Boot into SafeStrap after having files on your sdcard
3: Wipe Cache
4: Wipe Dalivk
5: Install ZIP file/files ( Ie InvertedAllIn1, or the different *.ZIP files you downloaded. They can be done one after another and then move to step 6 )
6:Reboot and enjoy
Inverted All in 1 ( Includes all 6 ZIP files below ) :
Inverted All in 1 LIQUID ROM ONLY ( Includes all 6 ZIP files below ) :
Inverted Calendar :
Inverted Contacts :
Inverted Email :
Inverted GTalk 4.0.4 :
Inverted MMS :
Inverted Phonesky ( ie Play Store ) :
Now for the other Apps that are Inverted. These are NOT flashable but install right on the device instead. To use any of these you need to make sure you have remove/uninstalled any version currently on your device. Once you uninstall them your device needs to be reboot first and then you can click on any one of these that you downloaded and put on your sdcard and it will install just fine
Gmail :
Google Music :
Google Reader :
Google Voice:
Google Plus :
You Tube :
I'd just like to say a personal thanks myself to Travp624 for letting me do this for everyone to enjoy using all the hard work he had already done. I'd also like to shoot a thanks out to DDX for getting me the stuff to host these files for everyones use.
Edit: For anyone using Bootstrap on there device and running an ICS ROM the link I posted above to Travp624's thread on RW will do the trick for you also. For whatever reason his files just do not work with SafeStrap and fail on install which is why I made these for everyone using SS.
- MrFrankRazr, DTrainMusikVein, jimyv and 5 others like this
Posted 08 June 2012 - 09:38 AM
- powerdan74 likes this
Posted 08 June 2012 - 09:43 AM
Posted 08 June 2012 - 10:17 AM
Is this the same
Not sure to be honest. you can try them if you want but my guess is you may have an issues installing. Every Inverted set I've seen online so for do not work with the ICS leaked ROMs we have do to the fact of us having to use SafeStrap. Most will work on Bootstrap but when trying to install via SS they will abort. It has to do with the updater-script.
Are they they same ones I tested? If you are busy PM me and I can set up some links for you
They are in fact going ot be the same. However the dev had a couple of things he wants me to post in specific about using them and if there is any trouble. So I told him I would not just drop the links without doing a write on his request. I should have time later today to get when I get home from work to get the OP updated and what not for everyones use
Posted 08 June 2012 - 10:19 AM
Posted 08 June 2012 - 02:44 PM
I've used the gmail and mms apps. The flashable zips wouldn't work so I extracted the apk, and replaced the ones in system/app and changed permissions. You should be able to do the same with the other inverted apps.
I'm on 209 using RAZRSafestrap-ICS-2.00.
- rzrtm likes this
Posted 09 June 2012 - 07:54 AM
Posted 10 June 2012 - 10:50 AM
- augie757 likes this
Posted 10 June 2012 - 01:16 PM
Posted 10 June 2012 - 02:19 PM
Posted 10 June 2012 - 02:28 PM
Talk app doesn't work for me on Nexus s with Codename Rom
This is for the razr isnt it?
Posted 10 June 2012 - 02:30 PM
That is correct. That is why it is posted in the Razr/Maxx section of this site. For ppl who want inverted for other devices aside from Motos they will need to go and look for that on there own. I only own Motos & a Gnex so any and al my testing is done on those devices ONLY.
Posted 10 June 2012 - 02:58 PM
Posted 10 June 2012 - 04:20 PM
Posted 10 June 2012 - 04:34 PM
Edit: Tested the All in 1 zip and it worked flawlessly on the KOA CM9 6/10 build!
Muchas Gracias Senor!
Posted 10 June 2012 - 04:37 PM
Posted 10 June 2012 - 04:50 PM
Posted 10 June 2012 - 05:42 PM
Posted 10 June 2012 - 09:23 PM
Posted 11 June 2012 - 12:55 AM
Talk also seems to be borked... is it just me having issues?
Go to settings- apps then clear talks data and should be ok
