[Mod] Inverted Gapps For Moto Ics Leak Roms Only ( Updated 7-7-12 )
#21
Posted 11 June 2012 - 03:35 AM
For the apk's that are not flashable. I used rom toolbox pro. To install app, fix permision and reboot. All are working fine.
Here are the ones I'm using
Contacts
Music
MMS
Play
Gmail
Reader
You tube
#22
Posted 11 June 2012 - 04:03 AM
I'm having issues with the market app on KOA B38 flashed over the .79 leak. Anyone else get this working?
Should work fine on that build. That is one I actually did testing on. Go to Manage App and clear the data dor the Market and try going in again and see what it does. I have had it happen a couple of times with Gmail & Market where I after installing I had to clear data & cache for those apps in Manage Applications and then all was good to go.
#23
Posted 11 June 2012 - 04:06 AM
Oh...I am very sad. I misunderstood the title of the thread. I read "Inverted Gaaps for Moto ICS leak ROMs" thinking they were for the the Moto leaks :-( I didn't realize they were for the ROMs built on the Moto leaks. :-( I very sad now. I no get inverted Gapps for Moto ICS leaks. :-( :::::::::
Yeah to inverted stuff on a /system that is NOT deodexed is a real pain to say the least which is why they can not be used currently unless you are running a ROM built off one of the leaks.
#24
Posted 11 June 2012 - 04:23 AM
#25
Posted 12 June 2012 - 01:50 AM
They work fine on my leaked 209 stock
#26
Posted 18 June 2012 - 05:23 PM
No dice on .211 though. Atleast not for me. Google music and youtube works fine though but i think that is it.
#27
Posted 20 June 2012 - 09:43 AM
#28
Posted 22 June 2012 - 03:46 PM
#29
Posted 22 June 2012 - 03:47 PM
Worked awesomely well on Arctic .211 Build. All of them!
Did you delete your current apps or just replace them?
#30
Posted 22 June 2012 - 04:06 PM
#31
Posted 04 July 2012 - 06:17 AM
#32
Posted 04 July 2012 - 07:20 AM
#33
Posted 07 July 2012 - 12:09 PM
#34
Posted 07 July 2012 - 01:11 PM
Edit: BTw I also posted an All in One for use with Liquid ROM. Tha tfile is ONLY good for use on Liquid tho. DO NOT try using it on other ROMs. Liquid has there setup done a little diferent which is why I posted a separate link for that ROM.
- mechatricity likes this
#35
Posted 07 July 2012 - 01:19 PM
#36
Posted 07 July 2012 - 02:22 PM
#37
Posted 07 July 2012 - 03:02 PM
also, protip. Don't go into data/app and delete the gmail apk. you will have problems. uninstall it properly, reboot, drop inverted gapps in data/app
#38
Posted 07 July 2012 - 10:20 PM
Youtube, gmail, playstore, g+, messaging and reader ..
The system apps I used root explorer and copied them to system/app after adding. bak to the original file name(had to rename a few to match stock names)
Google music (music2.apk) keeps removing the .bak extension leaving 2 music apps but works fine ...
Talk, calender and contacts are giving me problems.
Loving the BLACK
#39
Posted 08 July 2012 - 01:53 AM
#40
Posted 08 July 2012 - 02:09 AM
Arctic mms is blur based. This is cm9/aokp. It has nothing go flash overI wiped cache and dalvik before flashing the Inverted All in 1 with Safestrap, and all apps are working great except MMS. Any solution for getting MMS inverted? Using Arctic Rom .211.
