RSD Flasher PROTOTYPE has been updated with some new features that this crowd may enjoy...
[SOAK] 4.4.2 183.46.14 + 183.46.15 patch
#81
Posted 13 July 2014 - 05:03 AM
#82
Posted 13 July 2014 - 05:04 PM
Spinny thing?
Sorry, I couldn't resist!
- cmh714 and RikRong like this
#83
Posted 13 July 2014 - 05:09 PM
Spinny thing?
NO
- rickw likes this
#84
Posted 13 July 2014 - 05:27 PM
All kinds of warnings and messages are little spinny things
- ibolski and rickw like this
#85
Posted 13 July 2014 - 05:42 PM
I was going to ask the same question..didn't want to push my luck
Thanks ibolski
#86
Posted 13 July 2014 - 05:44 PM
Spinny thing?
ROFL
#87
Posted 13 July 2014 - 06:05 PM
Sent from my S-Offed One M8
- ibolski, SamuriHL, johnthehillbilly and 3 others like this
#88
Posted 14 July 2014 - 03:10 AM
Ah man!NO
#89
Posted 14 July 2014 - 04:30 AM
#90
Posted 14 July 2014 - 04:32 AM
Since you're unlocked, sure.
- sspartan likes this
#91
Posted 14 July 2014 - 04:42 AM
#92
Posted 14 July 2014 - 06:13 AM
UNIVERSAL can be run all the time except in the case of upgrades. If you're upgrading to a new version, keep data is probably appropriate. In this case, universal is fine since the upgrade is applying an OTA rather than upgrading with an FXZ. Hopefully that makes sense.
#93
Posted 14 July 2014 - 01:59 PM
#94
Posted 14 July 2014 - 02:05 PM
Given that the main fix is the bluetooth stuff, I'd say almost certainly yea.
- thewraith420 likes this
#95
Posted 14 July 2014 - 02:31 PM
#97
Posted 15 July 2014 - 05:46 AM
So is this soak update the same one that will eventually be sent out to everyone? I thought that for the KK OTA update they had 2 versions, the soak version 182.xx and the "official" version 183.xx. I am just wondering if I should just do this one now or there is any potential benefit in waiting for the "official" OTA update? Thanks for the info as always.
#98
Posted 15 July 2014 - 06:09 AM
I love Moto for creating all the confusion around this. There wasn't a "soak" vs "release" build. A while back people got split into two different versions showing up. If you ended up with 9.18.94, you would get build 182 OTA pushed to you. If you ended up with 9.30.1, you would get build 183 OTA pushed to you. The soak build that was originally published was from a user that has 9.18.94, and so it updated to 182. But others in the soak had 9.30.1 and got 183 pushed to them. Fast forward to this mess. If you're on 183, you should take this update. if you're on 182, well, who knows where that update is, but, I'm sure someone in the soak test probably got it. I don't have it nor have I seen it. Personally I recommend sticking with the 183 versions.
- cmh714, Board373 and exsquid like this
#99
Posted 15 July 2014 - 06:48 AM
- Board373 likes this
#100
Posted 15 July 2014 - 08:04 AM
Unless something drastic comes up during the latest soak, what was leaked will be what they push out more than likely as the official OTA.
Ok sounds good. Thank you both for the info.
