[Rom][Razr - Gsm] Miui-V4 Beta (Gsm)(6/15/12)(Done)
gsm rom miui gsm miui
26 replies to this topic
#1 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 10 March 2012 - 07:14 AM
Here We go today i have MIUI-V4 using DHACKER29 and HASHCODE ICS base.
HUGE Thank goes out to:
Hashcode for his knowledge and skills
STS-Dev-Team for the awesome contribution for the Moto phones
DroidTh3ory
Spryte
shahulvm
Adlx.xda
Pajn
ANY DEV working hard to make roms and awesome Apps
I HAPPY to SAY that GSM has official builds now..the first release has come out...so all GSM users that are ICS LEAK..i am proud to say MIUI official Release is out so i will no longer support it..
go to www.miuiandroid.com
I am proud to share that XT910 has won the poll on MIUI.com They are going to work on Official builds for XT910!
"The voting has ended, in accordance with the results: 1, the MOTO XT910, 2, Samsung Galaxy Note I9220, 3, Sony LT26i, 4, Samsung Galaxy S III, 5, HTC One S. The development team will be the first adaptation of the MOTO XT910 and Samsung Galaxy Note I9220, the other three models will be followed by adaptation."
found on MIUI.com
ICS Base from STS-Dev-Team - So You have to be on a 2.3.6 system for this rom to work ( had a tester on 2.3.5 it ran but bluetooth causes bootloop)
STILL GB KERNEL
changelog:
Initial Release;
3/9/12:Fix Applying Theme issue
3/14/12:
Add Front Facing Camera fix (thanks to rapmv78)
Added Missing MIUI apps that had to be translated---(thanks to DroidVicious)
cleaned up system and the init.d script
3/17/12:
Updated MIUI Base system to 2.3.16
Added all updated MIUI Apps-Yes i know some are in chinese-
Updated MIUI Home - there are more options for the launcher in /launcher settings
New Lockscreen-change the lock wallpaper if it looks weird on first boot-
Torch is working - Tip can hold Home button at lockscreen and torch will come on.
status bar options added in settings
*broke usb mass storage switch- but have a work around app installed for you Called USB Mass Storage*
3/20/12:
fixed usb mass storage connection to computer
translated MIUI app: Monitor and Antispam
add File Manager back
add CM gallery - MIUI gallery doesn't read external Sd
Updated Google Play Market
3/24/12
update system to 2.3.23
added new alarm clock app
add new settings
minor clean up
3/30/12
update to 2.3.30
Fixed alarm not snoozing and stoping sound
Optimise password-protected applications do not appear in the recent Task list
Optimisation of the recent task pane click-able area to resolve a mistaken click problem
Repair to clear the "Settings" no lock screen data leads to abnormal operation
Repair in some cases cannot ROOT
Repair screen vertex does not display rounded corners, the status bar interface displays the wrong information
Repair removing settings data leads to lock screen display issues, also launcher becomes unresponsive
Repair MoboPlayer playback FC issues
Update ALL MIUI APPS
4/20/12
update to 2.4.20
Fixed Phone FC on boot
update MIUI Framework
new MIUI System UI
Updated all apps to MIUI 2.4.20
updated lib files from MIUI
and other MIUI features
4/27/12
update to 2.4.27
Optimisation to improve the call log loading speed
Fix service provider to show owner information, information displayed incorrectly
Optimisation of Telecommunications number attribution
On-line picture library support for choosing contact photo via Theme Manage
Optimisation of merge duplicate contacts UI interaction
Fix in some cases, you cannot open the dial-up message dialogue page
Fix FC when selecting contact to send a new messag
Fix contact number attribution issues numbers stored with +44 / 07 for same contact do not show contact name
Fix problems sending Mms messages
Optimisation of new SMS time format method
New SMS / MMS application priority option to choose which application will receive the message first
5/4/12
update to 2.5.4
Optimisation to increase efficiency of loading list of installed applications
Fix problem setting Custom status bar notifications leads to FC error
Fix in some cases when recovering data operation is completed successfully, the result will be displayed as 0Bytes restored
etc
5/11/12
update to 2.5.11
New system search with set of sub search options
Optimisation of text editing interactions
Optimise Chinese Phonetics in T9 database
Optimised support for V4 Themes
etc
5/18/12
update to 2.5.18
New text editor function for magnifying glass by long-pressing text will show highlighted words in preview pane
Optimization to further improve interactive gestures in the text editor mode (will not display when the input box is empty when you press the cursor and Optimize double-click selection criteria)
Optimize text editor copy operations
Added quick entry to Calendar functions by opening status bar area and pressing on the date (left of screen) will directly open Calendar
Fix lock screen display delay issues
Added quick access to System Settings in status bar
Added new app switching animation transitions
etc
5/25/12
update to 2.5.25
Fix Exchange FC issues
Added when manually installing an application the system will automaticall scan the app for viruses and security issues
Optimisation of the switch controls to replace the ideographic check controls
Fix problem during call, cannot recognise some headphones when they are pulled out
Optimisation of T9 to improve the search, synchronisation, update and import efficiency of contacts and reduce space and memory usage
Optimise the alarm interface resources package is deleted will cause the alarm to FC
Fix problem setting LED light colours do not take effect
etc
*to let you i know i have noticed that some widgets this week don't work. for me I saw my Gmail widget never loaded properly*
6/1/12
Fix some applications, pressing the back key player gif results in locking
Remove the "Disable" button to disable the system applications on app info page to prevent incorrectly shutting down core services which may lead to stability problems
Optimise light-sensor strategy to tackle screen lighting issues
Optimise (CDMA) call ended still shows the green return to call information
Added support for displaying music spectrograph animations
Optimisation without SIM card will display the phone in Airplane mode
Optimisation of lock screen to provide 720P HD support
NEW Allow to show / hide system FC error messages (See developer options for further details)
fix widgets showing on desktop
New Monitor apk look
6/8/12
update to 2.6.8
Optimisation - when adjusting the clock minute selection, the clock does not automatically add / subtract
New call, new call reminder supports notification tone, can also be set up with prompts e.g.
New functions for stopping current program (press return key) with a longer response time
Add support for majority of original factory settings
etc
6/15/12
update to 2.6.15
Optimized 12-hour time-phased by the "AM / PM" to "morning, noon, afternoon, evening, and midnight,
Optimisation of third-party calling, allow the proximity sensor to turn on or off the screen
Fix in some case the wrong session is displayed from the search results page
Optimisation of desktop frame rate
Fix problems with gallery library FC issues
Optimisation of SMS keyword (spam) filtering rules
etc
* Here is a link to Full MIUI changelog, some changes don't pertain to are phone *
SoftKey Fix zip:
install zip after Intial install of MIUI
wipe cache
wipe dalvik cache
flash softkey fix zip
reboot
READ THIS:
please do a wipe data, wipe cache and wipe dalivik cache
Install with bootstrap
You don't have to install GAPPS they are include
Known issue in the Rom:
  • Camcorder
  • External SDcard doesnt mount-temporly i left file manager so you at least find files
  • Data doesnt come on by itself
  • When downloading anything your phone will warn you that you about downloading using data. - To fix that go to Downloads -> Menu button -> Settings -> Data Download Prompt
MIUI-V4 Alpha GSM:
MIUI-v4 Alpha GSM(3/14/12):
MIUI-v4 Alpha GSM(3/17/12):
MIUI-V4 Alpha GSM (3/20/12)
MIUI-V4 Beta GSM (3/24/12)
MIUI-V4 Beta GSM(3/30/12)2.3.30
link:
MIUI-V4 Beta GSM(4/20/12)2.4.20
link:
MIUI-V4 Beta GSM(4/27/12)2.4.27
link:
MIUI-V4 Beta GSM(5/4/12)2.5.4
link:
MIUI-V4 Beta GSM(5/11/12)2.5.11
link:
MIUI-V4 Beta GSM(5/18/12)2.5.18
link:
MIUI-V4 Beta GSM(5/25/12)2.5.25
link:
MIUI-V4 Beta GSM(6/1/12)2.6.1
link:
MIUI-V4 Beta GSM(6/8/12)2.6.8
link:
MIUIv4 Beta GSM(6/15/12)2.6.15
link:
Lets the sun and the moon collide! eclipserom.com
#2 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 14 March 2012 - 11:29 AM
Update is in the OP, has working front working Camera
  • skiwong20 likes this
#3 itsmehuey
itsmehuey
  • 13 posts
Posted 15 March 2012 - 04:04 AM
can I install this over the install of the previous build? (obviously after doing a factory restore/data wipe, dalvik-cache wipe and cache wipe)?
thanks man for all your efforts to bring MIUI to our RAZR's.
#4 itsmehuey
itsmehuey
  • 13 posts
Posted 15 March 2012 - 04:45 AM
btw u might want to update the OP - wallpapers do scroll depending on the wallpaper you choose.. and for me, data does automatically turn on, on boot.
#5 nchreyes
nchreyes
Posted 16 March 2012 - 06:07 PM
is there step by step guide for newbies?
#6 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 17 March 2012 - 11:30 AM
New Update in OP
#7 itsmehuey
itsmehuey
  • 13 posts
Posted 18 March 2012 - 02:30 AM
Sweet. Might have to give the update a try.. btw any news on DianxiOS? :)
#8 Bastard
Bastard
Posted 01 April 2012 - 07:58 AM
Hi! I lo ve miui
This Rom inside lenguaje Spanish?
Thx
Enviado desde mi XT910 usando Tapatalk xD
#9 p.floriani
p.floriani
Posted 02 April 2012 - 04:40 AM
the last update is in boot loop...someone has same bug
#10 HSD-Pilot
HSD-Pilot
  • 303 posts
  • LocationGermany
  • Current Device(s):RazR
Posted 06 April 2012 - 05:41 PM
You must flash the GSM-Patch!!! Even on GSM-Version of this Rom. Tested and running on German GSM-RazR;)
Sent from my XT910 using Tapatalk
Soundcloud <> Bassgrow
#11 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 20 April 2012 - 11:59 AM
updated rom ...check op..it is UNTESTED AS of RIGHT now so please let me know if it doesn't work
#12 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 20 April 2012 - 06:40 PM
new build...had to fix...should boot now.. zip should say MIUI GSM_2.4.20_v2.zip
#13 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 27 April 2012 - 10:18 AM
new build up
#14 qasim
qasim
Posted 03 May 2012 - 08:29 PM
flashed and works like a charm, have had it for almost a week now
i have had the following issues with it so far:
  • data toggles on/off itself
  • camera not working (opens but FCs)
  • a couple of apps i regularly use dont seem to be compatible with this ROM (e.g. Foursquare)
  • Signal bar doesn't seem to go higher then showing two bars
#15 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 04 May 2012 - 06:47 AM
alright. will b looking into the issues. i don't own a GSM razr but i do have someone to help test.
#16 skiwong20
skiwong20
    Developer
  • 172 posts
  • LocationFairfield
Posted 11 May 2012 - 04:53 AM
Update is up.
#17 Droid2drummer
Droid2drummer
  • 324 posts
  • Twitter:@imanotemaker
  • Google+:robertclarkga@gmail.com
  • LocationWarner Robins GA
Posted 11 May 2012 - 09:10 PM
All are GSM?
Sent from my Droid Razr using Tapatalk 2
#18 uberbdon
uberbdon
  • 367 posts
Posted 12 May 2012 - 09:25 AM
All are GSM?
What does this mean
#19 Droid2drummer
Droid2drummer
  • 324 posts
Posted 14 May 2012 - 11:35 AM
It means I'm cdma and can't use GSM builds unless they are ported.lol
#20 Guest_BDH_*
Guest_BDH_*
Posted 14 May 2012 - 03:58 PM
There's a CDMA version.
[Rom]Miui-V4-Beta--(5/11/12)
Also tagged with one or more of these keywords: gsm rom, miui gsm, miui
