Soak test ended - OTA push starting today
#81
Posted 13 March 2013 - 05:41 AM
#82
Posted 13 March 2013 - 06:48 AM
Was able to get into Recovery and restart the Utility. Seems to be working this time. Will try not to freak out again
I couldn't get the 1.9 Utility to set up my phone, but for some reason Matt's Unbrick utility worked instead. It sets up your phone so you can apply the xmas leak (you need it on your SD Card) and from the leak you can take the OTA.
#83
Posted 13 March 2013 - 07:12 AM
#84
Posted 13 March 2013 - 07:15 AM
Clearing the air...The Xmas leak and OTA are not the same. Xmas leak was 98.72.8 and the OTA is 98.72.16. I apologize if I confused anyone with my prior statement. What I should have said is if you plan on side loading this update, make sure that you have the correct file for the build version you are coming from. I am not sure what the difference is between those coming from ICS .211 and the JB leak that was released christmas eve. If you are on the leak, you can take the OTA and retain root with voodoo. The bigest thing that you have to do is make sure that you are 100% without a doubt stock rooted. No apps frozen, nothing taken away.
So, for anyone that is on X-Mas JB...
You Need to Boot back to Stock...be Rooted...on 3.11 SS ...than take OTA?
Its Bubba
~Stubborn In Your Bones~
*FlyingJelly*
#85
Posted 13 March 2013 - 07:23 AM
Sent from my Motorola Galaxy s3 using Xparent Red Tapatalk 2
#86
Posted 13 March 2013 - 07:36 AM
You can go back to .211 via Dual Boot...When u say stock... do u mean just boot up to my unsafe side which is the Xmas leak? I was under the assumption that o can't go back to .211 once I took the Xmas leak
Its Bubba
*FlyingJelly*
#87
Posted 13 March 2013 - 09:34 AM
No, that means they sent you details about what to expect IF you got picked for the soak. Just because you filled out a survey and got an email, doesn't mean you can expect anything. Again, that was throwing your name in a hat. I only received an email that I was picked and to expect the file about 8 hours before they pushed it. Getting details is different then getting picked.Mhm, actually they did... Ah wait, I got the original mail here
After filling out the questionaire, they did write in a way that I could expect my participation in the JB test to be a sure thing, instructed me on several details of the testing + feedback process, showed me around some areas of the feedback section in the moto forums etc.pp...
Therefor I think I had a reasonable expectation to hear from them again. Seems they thought otherwise.
#88
Posted 13 March 2013 - 09:35 AM
you have to remove and delete safestrap. stock means stock like what it was like when you walked out of the store with it. stock doesn't include safestrap.Clearing the air...
Its Bubba
*FlyingJelly*
#89
Posted 13 March 2013 - 09:38 AM
Its Bubba
*FlyingJelly*
I'm not sure that is correct. The dual boot was created so that people on ICS could boot the JB kernel and run JB roms without installing the Xmas leak. Maybe you could run ICS roms with the ICS Kernel I'm not sure but why would you want to since 90% of the Roms are up to the Xmas JB leak. But is does not take you back to .211 on your stock rom. Once you go JB there is no going back.
#90 Guest_BDH_*
Posted 13 March 2013 - 09:41 AM
Exactly correct. Dual boot method was just a fail safe for ICS users. There's no way you're going back to ICS if you flashed the JB update. Ever.
#91
Posted 13 March 2013 - 10:03 AM
You're Right from a Stock ROM side... I'm speaking from Safestrap side to .211...that's why I mentioned Dual BootI'm not sure that is correct. The dual boot was created so that people on ICS could boot the JB kernel and run JB roms without installing the Xmas leak. Maybe you could run ICS roms with the ICS Kernel I'm not sure but why would you want to since 90% of the Roms are up to the Xmas JB leak. But is does not take you back to .211 on your stock rom. Once you go JB there is no going back.
Its Bubba
*FlyingJelly*
#92
Posted 13 March 2013 - 10:12 AM
Its Bubba
*FlyingJelly*
Can't I just go Into fastboot and flash the soak zip over the Xmas leak? Or will that fudge stuff up?
#93
Posted 13 March 2013 - 10:28 AM
I do understand what the Stock side of town is ...you have to remove and delete safestrap. stock means stock like what it was like when you walked that said of the store with it. stock doesn't include safestrap.
Just want to be sure...conflicting posts with procedures...
Its Bubba
*FlyingJelly*
#94
Posted 13 March 2013 - 08:31 PM
1. unfroze apps
2. via voodoo unrooted/rooted
3. left it rooted
4. took the ota JB, let it install
5 when phone booted up it says "unfortunately, the process com.android.phone has stopped."
6 clicking okay restarts it, but it immediately fails and the voice says "loss of service, verizon wireless"
7 rebooted, same thing
Thanks for any help
#95
was on jb xmas leak, rooted. Preped for ota JB
1. unfroze apps
3. left it rooted
Thanks for any help
I'd start with a Cache wipe...
#96
Posted 13 March 2013 - 08:45 PM
wiped via Titanium Backup, then rebooted, still the same problem
#97
Posted 13 March 2013 - 09:03 PM
did a wipe via the settings and reboot still no goodI'd start with a Cache wipe...
#98
Posted 14 March 2013 - 07:55 AM
Sent from my DROID RAZR using Xparent Skyblue Tapatalk 2
#99
Posted 15 March 2013 - 10:14 AM
1. I ran OTA root keeper before the update.
2. Clicked install for the update and let it do it's thing.
3. ran OTA root keeper after update.
4. Installed Superuser.
5. ran OTA root keeper again.
Everything seems to be alright because running wifi tether and it requires root.
- Redalert likes this
#100
Posted 15 March 2013 - 07:18 PM
Sent from my DROID RAZR MAXX using Tapatalk2
