So I have recently Flashed ARCTIC ROM and it all went bad, was stuck and bootloop and forgot to flash CWM recovery. After lots of research and time I managed to fix my phone here is how:
Download this fastboot file on your pc & extract the file:
Then download RSD lite from here & install it on your pc:
Install moto drivers on your pc here it is:
Now open the Rsd lite on pc, browse an XML file that you extracted from fastboot files and put it on rsd,
Turn of your phone, click on vol- vol+ & power buttons at the same time, now you entered to boot menu,
Select Ap fastboot (vol- to scroll & vol+ to select)
Then connect phone to the pc via usb port,
When you see "connected" in rsd lite, click on start key on rsd & be patient to flashing fastboot files, it takes about 7-8 minutes
Thank you zeidof for all your help!
How To Fix Razr, If Stuck On Bootloop/bad Flash Using Rsd Lite And Fastboot
newbieshwa
, Mar 10 2012 04:48 PM
fastboot bootloop RSD lite rom arctic fix
No replies to this topic
Also tagged with one or more of these keywords: fastboot, bootloop, RSD, lite, rom, arctic, fix
