#21
Posted 02 December 2011 - 03:00 AM
I was thinking after watching a great series on setting up your device to maximize battery life, many of the data polling tip savers don't apply to razr users using smart actions. If you add disable cell data there is no background data use during a triggered time frame. So setting FB, twitter, email from push to hourly checks really aren't required with data disabled. So using an app to do the same things smart actions can do will cause extra battery drain to run the app and the smart action.
Just some random thoughts.
Meeting time.
#22 Guest_DirtyDroidX_*
Posted 02 December 2011 - 07:11 AM
A couple of things... I did a factory reset via the menus vice bootstrap recovery. I had major screen redraw when exiting apps back to home screen. Mostly noticeable when backing out of text message app. I noticed a decrease in performance after installing juice defender. Since I removed it I still had redraw so that prompted me to try a reset. So far back to normal. I went ahead and wiped the internal and 32gb sd card installed from my tbolt.
Meeting time.
I have found with messing with three separate razrs, they are very sensitive too SD support and the cache partitions. Especially the dalvik cache. I removed alot of bloat and my phone still was lagging and kids flickered a bit. I use cache mate,its free, you can clear regular cache and specify certain apps. Thus helps having a clean house so to speak. I use it a few tines a day. With Boston removed and the original SD in use I'm running smooth with good battery life. Also if you put a diffreny SD card in make sure there is not existing data on there. The smart actions I've noticed does suck battery but again it depends what you use it for. I will be curious too see a update of the in the future. Thanks for the info scrub
#23
Posted 02 December 2011 - 07:24 AM
The old cache cleaner. Forgot that one.
I did swap SD cards. No major hangups I was going to format but wanted to see the net effect.
The you tube series I mentioned was covering the bionic. Search tempting guides. Good info for new users to properly set up their phone.
#24
Posted 02 December 2011 - 05:08 PM
The sad part is that my beloved razr has had an early departure and due to unforeseen issue I wont be getting another the device started having random reboots even after wiping clean, due to the verizon rep at the store i was not allowed a device swap. It worked out for the better as VZW refund my restocking fee.. I'm gonna jump on the Gnex if and when its released and if i don't like it well ill be coming back to the Razr.
Sorry for hijacking the thread with my sob story.
#25
Posted 02 December 2011 - 05:15 PM
What kind of stuff did you task kill?
#27
Posted 19 December 2011 - 02:32 PM
#28
Posted 02 January 2012 - 01:16 PM
#29
Posted 02 January 2012 - 03:19 PM
#30
Posted 19 January 2012 - 03:31 PM
Also, idk if any of you rooted guys use setcpu, but I made a profile for when the display turns off for it to kick the cpu down to 300mhz min/300mhz max. Helps a TON. I have had good results freezing bloat with Titanium Backup too. Right now I am testing my battery with wifi, calls/texts, music, and some apps. I will report back when my battery dies! lol
Did that too in addition to this:
I for one have had great success with juice defender and just leaving it on balanced. All it does is kill your 4G about a minute after the screen times out and reactivates it every 15 minutes. Your phone still received calls, and texts. As soon as the screen comes back on within a few seconds 4g is reconnected. Its extended my battery life by another 6 hours or so.
#31
Posted 28 January 2012 - 03:29 PM
#32
Posted 31 January 2012 - 06:55 AM
Are you running autokiller? I really liked AK, and thought it was juicedef. draining the battery, but when I froze Autokiller and let JD run, my battery lasted at least twice as long. Has anyone else noticed this with Autokiller?
#33
Posted 31 January 2012 - 09:17 AM
Any app like AutoKiller, Task MAnager...etc are a totaly waste and waste more battery then they are worth. Probably why you are seeing such a big difference now.
#34
Posted 31 January 2012 - 11:49 AM
ddemlong...typically how much usage is from voice calls for you?Did that too in addition to this: I for one have had great success with juice defender and just leaving it on balanced. All it does is kill your 4G about a minute after the screen times out and reactivates it every 15 minutes. Your phone still received calls, and texts. As soon as the screen comes back on within a few seconds 4g is reconnected. Its extended my battery life by another 6 hours or so.
And does anyone know what mediaserver is? It randomly sucked most of my battery last cycle.
#35
Posted 31 January 2012 - 06:41 PM
no task killer
#36
Posted 31 January 2012 - 06:45 PM
Um, voice calls can vary from little over an hour to several hours depending on my day. Media Server I believe is the gallery and the social services that you can use to sync share your photos on (twitter, FB, Photobucket etc). I have frozen a lot of apps so I dont really have much usage from media server. Just the basics for me. I don't want things automatically uploading stuff and if I want to I will use the apps.
#37
Posted 07 February 2012 - 07:06 AM
#38
Posted 08 February 2012 - 03:09 PM
-turn off anything I won't be using, like wifi (my home internet is much slower than LTE), bluetooth, gps (put a power control widget on your desktop, or use a pulldown toggle to enable it only when you need it)
-set individual apps to sync manually or not refresh themselves, or disable auto-sync altogether if you can (I realize some may not like this, personally I check my phone often enough that I prefer getting notified about things when I check them, just like on a pc. I don't like being bombarded with tweets, emails, and facebook messages all day, as I'll see this when I check them myself).
-turn off pocket detection
-dont use live wallpaper
-freeze what bloat you can live without, being aware that if you remove things you need it won't be easy to get them back, and if you remove anything from a stock rom you'll have to fastboot back to get updates
-put any misbehaving apps in the Auto-End list in the stock task manager. Things like Facebook and Amazon App Store tend to spawn processes on my phone all the time, so putting them in this list ensures they are killed and not restarted until you open them
-use Smart Actions and set it to disable Mobile Data when the screen is off, and employ whatever wifi management policies benefit you, if you use wifi
-use AutoKiller Memory Optimizer with whatever settings you find work best for you (but DO NOT use a third-part task killer app)
-use JuiceDefender Ultimate, and set the CPU max idle speed to 600mhz, change your governor to mot_hotplug, and play around with the brightness settings (I lowered the minimum brightness and made the overall curve a bit less bright). Use whatever other functions benefit you, though I find Smart Actions to be better at data management than JD.
That's all I can think of off the top of my head. I don't get stellar battery life, but I can get through an average day just fine. I use my phone alot for browsing, emails, social networking, some Pandora, etc in addition to the usual calls/texts, and have no problem getting 11-14 hours on average before it dies. This of course goes down if I listen to Pandora ALOT, keep the screen on for long periods of time, and drops rapidly if I'm streaming videos or playing games. There are times I like to do these things, but not on an average day, and I can usually throw it on the charger for a bit of a top-up around dinner time and go all night with any evening activities I have going on. I'd still love the Maxx battery so I could play games and watch videos and such without concern, or get through a full day and night without having to plug it in at all, but I do find that it lasts long enough to not be a problem, and much longer than my Droid Charge.
I still plan to try out Abysm though once it gets updated to the .173/.174 base, as alot of people seem really impressed with its battery life (which strikes me as odd to be that much of a change, but its worth a shot).
#39
Posted 18 April 2012 - 11:23 AM
the longest i got on that iPhone to last between charges was 3 days of moderate usage.
as for my droid razr, my last test was the best: 3 days +2 nights = a little over 70 hours on one battery charge
for this test,
- returned to stock
- dumped ALL of my battery savers (juice defender, etc.)
- manually turned wifi/data on/off when needed
- mostly stayed on wifi (huge battery saver!)
- use task manager and smart actions
phone worked great! better than it had with my battery savers and GoLauncher.
and i was freaking so excited watching that battery level stay!
oh yeah, also made sure screen was set to power saver as well.
task manager and smart actions are the way to go!
#40
Posted 05 May 2012 - 09:46 PM
Llama has been working pretty well for me. I've pulled more than 58 hours on my maxx.
