#41
Posted 09 May 2012 - 07:00 AM
#42
Posted 09 May 2012 - 09:03 AM
#43
Posted 09 May 2012 - 09:20 AM
I found that smart actions are usless
Agreed
#44 Guest_BDH_*
Posted 10 May 2012 - 01:30 AM
#45
Posted 10 May 2012 - 06:03 AM
While I don't use smart actions to prolong battery, I absolutely love that app.
-I use them to turn on my music app when I put the phone in my car dock
-To put my phone on silent during sleeping hours while still letting through important calls from my wife and daughter
-To turn off my gps at work since it just constantly looks for a single due to the building I am in
-To set my brightness to minimum whenever it is in any dock.
I also use verizon wifi auto on app to turn on wifi when I am at home and off when I leave.
I love this stuff. Finally feel like my SMARTphone is actually getting smart.
#46
Posted 10 May 2012 - 10:19 AM
:-D :-D
#47
Posted 27 May 2012 - 04:16 PM
#48
Posted 29 May 2012 - 12:36 PM
4G Toggle by We Make Better Apps:
This allows you to quickly select from 4G to 3G when not in a 4G area. Great widget that I use frequently.
Data Enabler Widget by farproc:
This allows you to disable 1x, 3G and 4G when your in those nasty areas and don't want to waste battery, or you're on WiFi (that's what I use it for primarily)
Both widgets have helped me tremendously. I don't believe that Smart Actions will do you any good unless you change the settings specifically to your everyday life, and let's face it, things change! I use Smart Actions for bedtime and and In-Car, but that's about it.
I've only had my Razr Maxx a week and last weekend it lasted me about 36 hours total. (1 Day and 12 hours) with heavy use at first, and then medium use the rest of the way.
If you feel the need to buy me a beer, or help pay my bills, here's the link:http://bit.ly/O4ZnLW
