1% Or Some Other Accurate Battery Mod For Ics Leak?
Posted 05 April 2012 - 02:01 PM
I'm wondering if anyone knows if there's either a 1% mod, or some other sort of "accurate" battery mod available that will work on the ICS leak? I know that many of the available custom GB roms contain this feature, just wondering if anyone has attempted to port/flash onto the ICS leak? Thanks!
Posted 05 April 2012 - 02:03 PM
- PillClinton and cynnar like this
Posted 05 April 2012 - 02:04 PM
Someone please correct me if I'm wrong, but I don't think this is possible until a deodexed version is built.
You're right, I forgot all about the need to be deodexed... D'oh! With that said, is anybody working on deodexing the leak?
Posted 05 April 2012 - 02:11 PM
Posted 05 April 2012 - 02:14 PM
battery monitor shows 1% accurate with the leak. its free in the market.
Thanks for the suggestion, but I really don't want to add another app. I'll just have to be patient & wait for a deodexed build so I can actually mod the system instead
- JBeXX likes this
Posted 06 April 2012 - 04:29 AM
Posted 06 April 2012 - 10:43 AM
I haven't tried it, but over on xda they had a 1% mod specifically for the leak.
Thanks for the heads up, I found it, going to give it a try now since it doesn't specify you need to be deodexed. Crossing my fingers it doesn't brick me!
Edit: Not going to bother at this time, found a post saying it is still in 10% increments. Figured it was too good to be true. Wondering if this might fix the system issue I was having with the battery not reporting correctly though? Anyone else flashed this yet?
Posted 06 April 2012 - 12:40 PM
sliced by my Razr on Tapatalk
- justin75 likes this
Posted 06 April 2012 - 12:57 PM
Hey pill that link is download of mod, could you post link to thread?
Here you go:
Posted 06 April 2012 - 01:28 PM
Posted 09 April 2012 - 12:24 PM
I am fear my blade!
Posted 09 April 2012 - 12:34 PM
Sorry couldn't edit for some reason
I am fear my blade!
Posted 10 April 2012 - 05:32 PM
I am fear my blade!
Posted 10 April 2012 - 05:38 PM
I haven't had any battery irregularities since this mod either, don't know if it was the mod or the calibration
I am fear my blade!
Can you post a screen shot?
Posted 11 April 2012 - 03:55 AM
I am fear my blade!
Posted 11 April 2012 - 04:40 AM
Posted 11 April 2012 - 06:08 AM
I am fear my blade!
Posted 15 April 2012 - 12:15 PM
Posted 15 April 2012 - 12:38 PM
is there a differance between razr bootstrapper and ics razr bootstrapper if so where can i get the ics razr bootstrapper
Here in the development topic.
Posted 15 April 2012 - 12:40 PM
Also tagged with one or more of these keywords: ICS, ICS Leak, Battery, Battery Mod
