1% Or Some Other Accurate Battery Mod For Ics Leak?
#21
Posted 16 April 2012 - 07:42 PM
#22
Posted 16 April 2012 - 08:12 PM
Hope this helps!
#23
Posted 17 April 2012 - 06:07 PM
That's not weird. The stock is set too read in 10, but the stock framework is set for 20, this is why you can mod it to 10. The app is then taking the data on the phone and producing an "average" or calculated value in between the 10's. To get a true 1% your have to wait for a custom rom.
Hope this helps!
Sweet. Thanks for the info.
#24
Posted 18 April 2012 - 05:28 AM
is there a differance between razr bootstrapper and ics razr bootstrapper if so where can i get the ics razr bootstrapper
Everything you need or may need one day:
- fastfoodfred likes this
#25
Posted 18 April 2012 - 07:42 AM
- PillClinton likes this
#26
Posted 18 April 2012 - 07:57 AM
:-D :-D
#27
Posted 18 April 2012 - 08:01 AM
#28
Posted 18 April 2012 - 03:12 PM
sent from Dr. dre's studio with eminem.
#30
Posted 18 April 2012 - 03:36 PM
Should j let the phone run out before a full, uninterrupted charge?Common problem on the ICS leak. The battery stats are not correct. Just let it charge all the way up.
sent from my rooted ICS running RAZR with bootstrap alongside with beats audio hack and a battery mod. have a nice day you iPhone hating friends.
#31
Posted 19 April 2012 - 06:52 AM
Rooted Droid Razr ICS Leak
#32 Guest_BDH_*
Posted 19 April 2012 - 09:31 AM
And i did wipe battery stats right after installing ICS leak with ICS leak Bootstrap. Didn't know if that would help but i did it anyway. Lol
It doesn't lol.
#33
Posted 19 April 2012 - 01:39 PM
#34
Posted 19 April 2012 - 02:28 PM
Oops nope i wiped battery stats with ICS bootstrap for ICS leak. My bad on the wording. LolWyld, you installed the leak with ICS bootstrap? I thought it needed to be installed with ROM manager and no bootstrap installed?
#35 Guest_BDH_*
Posted 19 April 2012 - 08:46 PM
I would. Let it run completely dead until it shuts off (I know I'm going to catch crap for saying that.) Then if possible, let it charge overnight, with the phone off.
#36
Posted 20 April 2012 - 06:06 AM
Yup youll prob catch slack for saying it, but in my exp its best, most reliable way for accurate bat calibration. I dont do it often, but when having issues like others i let mine die out.
I am fear my blade!
#37
Posted 20 April 2012 - 06:13 AM
#38 Guest_BDH_*
Posted 20 April 2012 - 10:24 AM
I've found that nothing makes a difference when it comes to calibrating a battery... I haven't calibrated a battery since my droid x days years ago. I think it's even been proven by Android devs that calibrating your battery does absolutely nothing.
Wiping batt stats does nothing to improve battery performance. Conditioning does though.
#39
Posted 20 April 2012 - 10:57 AM
Conditioning you mean fully discharging the battery and then recharging it while powered off?
#40
Posted 23 April 2012 - 03:33 PM
Also tagged with one or more of these keywords: ICS, ICS Leak, Battery, Battery Mod
