I found this posted as a comment on a website somewhere:
"Go into aShell, check the “Root” box at the top, go to File Explorer, then go to data -> data -> com.motorola.android.providers.settings -> databases -> settings.db, open it with aSQLiteManager, click Settings -> Data, click “PgDn” until you get to 150, click “Edit”, change the value to 0, then press the back button soft key until you are prompted to save the changes back in aShell, save the changes, and reboot your phone. You of course still need to have your phone rooted for this method."
EDIT: Just tried this method myself and it works. Was using the WifiTether Beta app before this. I'm on the ICS Leak with DTs CMPLX Script installed.
after i open it with sq manager, it only goes to 108 not 150
