after i open it with sq manager, it only goes to 108 not 150
Check 79 I think.
Posted 25 April 2012 - 05:05 PM
Posted 26 April 2012 - 11:30 AM
Posted 12 May 2012 - 12:51 PM
Only works if you do it on 173 before updating, then again in ICS from what I've read.
Posted 12 May 2012 - 02:13 PM
Posted 12 May 2012 - 06:19 PM
Posted 25 June 2012 - 11:15 PM
Posted 26 June 2012 - 04:25 AM
I have used SQLite editor before on GB to enable the WiFi tether without the entitlement check, but now on .211 when I try to change the field to zero it gives me an error message "Update Failed - error code 14: unable to open database file" I am rooted using matts 1.7 utility and using chainfires SuperSU apk.
59.57KB 15 downloads
Can anyone give me any suggestions on how I can fix this?
Posted 26 June 2012 - 05:36 AM
if your on a razr you could have done that and not payed a centI have had so many problems using the Wireless Tether app not just on the Razr Maxx but also on the Samsung Droid Charge as well as the Thunderbolt. So, when I saw EasyTether on a 50% sale on the Amazon Appstore, I just splurged and bought that. The only downside is you have to use a USB cable but at this point, I just want a reliable app that I can tether with during emergencies.
Posted 26 June 2012 - 05:22 PM
Posted 26 June 2012 - 05:43 PM
Posted 27 June 2012 - 10:58 AM
Posted 27 June 2012 - 02:40 PM
Posted 28 June 2012 - 04:42 PM
Posted 28 June 2012 - 05:08 PM
Posted 28 June 2012 - 09:39 PM
SQL Does still work. However, you do have to find line 79, not 150. it took me four tries to to realize that it was in a different spot. However, note to all, the hack does not work until you reboot. If you don't you will get the Verizon billing notification.
Posted 28 June 2012 - 10:22 PM
Posted 29 June 2012 - 11:08 AM
Posted 30 June 2012 - 04:04 PM
Posted 01 July 2012 - 03:27 PM
Posted 06 July 2012 - 06:15 AM
