What app are you using to change it? I use Rom Toolbox ProSent from my XT926 using Tapatalk 2
I'm using the ROMs built in "performance" settings. Likely the problem, I'll try out ROM toolbox.
Posted 11 May 2013 - 05:47 AM
Posted 11 May 2013 - 09:07 AM
Posted 11 May 2013 - 09:20 PM
Updated. Go find changelog and download in OP.
Posted 11 May 2013 - 11:06 PM
shweeeet, flashing now! c:
Posted 12 May 2013 - 08:44 AM
is this compaible with fuzion rom?!
Posted 12 May 2013 - 09:13 AM
Posted 12 May 2013 - 09:58 AM
If Fuzion ROM is AOSP based it is.
Sent from my Nexus 4 using Tapatalk 2
Posted 12 May 2013 - 11:12 AM
Posted 12 May 2013 - 03:39 PM
I'm noticing my battery drain a bit quicker. I used the Trickster app to disable mpdecision, is it the intelliplug thing that could be causing this? It's not as bad as the stock CM kernel, and its only slightly worse than before. Performance seems about the same but my phone stays slightly warm sometimes.
Posted 12 May 2013 - 03:52 PM
Ha! Mine has been just horrible:
333.03KB 50 downloads
Albeit, I have One More Clock running, live Ocean HD wallpaper and whatnot, but 8-9hrs on this Maxx HD battery is just sad. I'm not saying it's this kernel and I know its just a matter of time when custom ROMs for our device will get as good (if not better than) battery life that of the stock ROM.
Posted 12 May 2013 - 05:23 PM
Posted 12 May 2013 - 05:30 PM
Wrong screen shot? With that drain you should get over 15 hours of battery life.
Could just the kernel settling in?
Posted 12 May 2013 - 05:34 PM
Maybe but the drain takes a steep dive after 50-60%. I recharged and wiped battery stats. See what happens after a couple full charges. Btw, how long does it take for the kernel to settle in? And would it be best to wipe system, mount and flash the new kernel? Thought I remember you saying to just flash it.
Sent from my rooted Droid RAZR Maxx HD using Xparent Cyan Tapatalk 2
Posted 12 May 2013 - 06:25 PM
Yikes. I've been at it for about 11.5 hours, 1.5 hours of screen time, and it's at 71%. I'll try to wear it down some more and see if my battery takes a dive. It's only been installed on mine for about 10 hours at this point.
Posted 12 May 2013 - 07:38 PM
This has improved my battery big time thank you so much. i am running nitros elemental X rom it is great and he is working on more for it.
Posted 12 May 2013 - 08:19 PM
can I flash this over cm10.1 on my Razr m?
Posted 12 May 2013 - 08:28 PM
Posted 12 May 2013 - 08:30 PM
Posted 12 May 2013 - 08:31 PM
wait you said rzr m that i am not sure of.
Razr M and Razr HD share same CPU and kernel, you can flash it over anything 4.2.2 and AOSP. So yes, you can flash it over CM10.1.
Posted 13 May 2013 - 05:43 AM
