[Mod]Droid Razr Ics Leak - Deodexer
#121
Posted 02 May 2012 - 12:41 PM
#122
Posted 02 May 2012 - 12:52 PM
whats the latest safest ICS leak i should try then? its a little bit confusing with all the names (mainly the numbers lol)
#123
Posted 02 May 2012 - 01:09 PM
#124
Posted 02 May 2012 - 01:15 PM
75
where can i get it? i been looking for it everywhere
#125
Posted 02 May 2012 - 01:21 PM
Sent from my DROID RAZR using Tapatalk 2 Beta-5
#126
Posted 02 May 2012 - 01:30 PM
#127
Posted 02 May 2012 - 01:38 PM
#128
Posted 02 May 2012 - 02:30 PM
Hello???
#129
Posted 02 May 2012 - 04:15 PM
#130
Posted 02 May 2012 - 04:23 PM
This did not doing anything to me phone. I fallowed the instructions. Wiped all cashe and flashed. It said it installed but yet I still have boat wear on my phone. Did I do something wrong? I am on. 75 ics.
Uhhhh... I am having trouble figuring out if this is a serious post...
If it is. This will not remove Bloatware. It does not say anywhere that it will. This only Deoxdexes the files to make it easier to alter some files to get things like 1% battery mods to work properly...
#131
Posted 02 May 2012 - 08:23 PM
#132
Posted 02 May 2012 - 10:16 PM
I apologize. I thought it was a debloater. What Deox ment.
Basically lets you flash things like 1% mods, themes and other stuff. Basically for theming though.
#133
Posted 02 May 2012 - 11:19 PM
#134
Posted 02 May 2012 - 11:24 PM
#135
Posted 02 May 2012 - 11:26 PM
Hey Emerican, if you are needing a tester for something on the 85 i will give it a try, especially if the worst is just a SOFT brick which we can now recover from!!Oh one other thing... just to let you'll know... I'm currently working on not only debloating but mostly debluring the leak. I've got a few patches and a few additions to do before its ready for release... but I may have a pre-release for some testers before it goes live. No ETA as of right now. But its in the works.
#136
Posted 02 May 2012 - 11:28 PM
OK! wish it was for 85! as am up allnight tonite at work and bored!! thanks tho! will test if needed and you think the worst would be just a soft brick that i can use the recovery method too fix!!I'm about to release one for 84 in a few minutes (or whenever the file finishes uploading). Not sure on 85 yet.
#137
Posted 03 May 2012 - 01:45 AM
#138
Posted 03 May 2012 - 01:58 AM
?What do u think is worst case scenario? soft brick?Lol. Well I'm sorta stuck on 84 for now. So most likely anything ill be doing for the time being will be released for that. Would it be possible that the. 84 deodex would work on. 85... sure but its untested...
#139
Posted 03 May 2012 - 02:23 AM
#140
Posted 03 May 2012 - 04:54 AM
