[Mod]Droid Razr Ics Leak - Deodexer
#101
Posted 27 April 2012 - 03:04 PM
#103
Posted 27 April 2012 - 04:59 PM
In the meantime EmericanX, I removed the dockservice.odex and seeded it...hope it saves you some time so you can work on v2...
Edited by MartyChubbs, 27 April 2012 - 06:01 PM.
#104
Posted 27 April 2012 - 08:06 PM
#105
Posted 28 April 2012 - 05:44 AM
#106
Posted 29 April 2012 - 10:21 AM
#107
Posted 30 April 2012 - 03:46 PM
#108
Posted 01 May 2012 - 01:23 AM
#109
Posted 01 May 2012 - 09:55 AM
is there .84 deodexer?
i need a 1% battery so bad!
#110
Posted 01 May 2012 - 10:06 AM
#111
Posted 01 May 2012 - 10:22 AM
#112
Posted 01 May 2012 - 10:28 AM
#113
Posted 01 May 2012 - 09:36 PM
Have you tried using adb to push superuser to your system/app directory? and also, I heard that z4 root works for the DroidX, maybe it will work for us, lol. If that still does not work you could try modifying the original update file and put superuser into the system/app folder and try flashing??? If anything though, make sure to reinstall superuser via google play and try using the terminal method to get the backup back. Again I am just throwing ideas out there lol.Let me know what you need help on. Since we're both on 84 we'll get it knocked out! That way i can really start playing!!! Wait! I still need to figure out how to get root back.. haha
#114
Posted 01 May 2012 - 09:42 PM
If you fuxxed your phone up, you can get back to stock. Although this is more of a mash buttons till it get fixed way, you still are back to "stock" lolololol.
#115
Posted 01 May 2012 - 09:48 PM
#116
Posted 02 May 2012 - 01:12 AM
BTW, I just kinda realized this right now. The way to unbrick your phone is also the way to fastboot back to stock .84 leak. Flash .181 fastboot files, which DO wipe, then use recovery to install .84 again and you are back to stock. SOOOO my sumation:
If you're not soft bricked, you can factory reset and you're back to stock 84/85. Worked for me anyways after uninstalling most of the bloat. I retained root as well.
#117
Posted 02 May 2012 - 09:47 AM
#118
Posted 02 May 2012 - 12:21 PM
do i just flash this over CWM?
or do am i suppose to go back to stock .173 and then flash this?
#119
Posted 02 May 2012 - 12:28 PM
#120
Posted 02 May 2012 - 12:30 PM
This is for the first Moto ICS leak ONLY. Not ICS roms based on the GB kernel. So no, this isn't for that rom.
ah i see. so i would need to go back to stock, install the leak and then this mod? correct?
