Stuck at Boot Loader Unlocked
Boot loader stuck bricked
4 replies to this topic
#1 phillipshepard
phillipshepard
  • 10 posts
Posted 13 June 2013 - 09:25 PM
So I rooted and unlocked my device and was trying some Roms. Well tried the Rage rom and it froze and had some errors. Tried to install liquid smooth and that froze too. Restarted the device. Now I cannot get in to recovery or anything? Its stuck at the warning Boot loader. Any ideas? Thanks a ton for you help.
#2 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 14 June 2013 - 06:54 AM
Only because you didn't specify - did you install TWRP or CWM?  How did you install the ROM?
Also, did you install the 4.1.2 stock kernal?  (I think this how you ask)  to start the process?
Did you WIPE, WIPE, WIPE?
Proud father of a US Marine
#3 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 14 June 2013 - 07:04 AM
Hold power and volume down for 10sec then quickly hold both volumes and power. Then you will get options choose recovery. Then either restore your backup (assuming you made one) or try to flash again and make sure to follow the directions. Did you mount system after flashing
  • newskate9 likes this
sig made by
Rinkle McBally
#4 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 14 June 2013 - 07:07 AM
I forgot to mention the "mount" part - good catch.
  • shane1 likes this
#5 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 14 June 2013 - 02:32 PM
howd you make out?
i meant mount before flashing  :blink:
Edited by shane1, 14 June 2013 - 02:42 PM.
sig made by
Rinkle McBally
Also tagged with one or more of these keywords: Boot loader, stuck, bricked
