The base instructions and main download here were originally intended only to update to the .210 leak from a previous > .84 leak. So the main download and instructions are geared towards that. If you want to use the utility to move to the .211 leak (or presumably beyond .211) you need to read the instructions and download the updated script file and associated bootxxx.img file.
For those of you on .20x (and most probably .8x too) that want to upgrade to .21x, I have made some tweaks to Matt's 1.6 Utility to only flash the system.img and the preinstall.img from 6.12.181 and the 6.16.21x boot.img. I have also added in the new 4.0.4 ICS root method as posted here by DDX (I apologize but I do not know whom to credit for that particular work right now) and added a couple of other little options to the utility that I like to use. I have personally tested this on my phone taking it from 6.16.209 to 6.16.210 and then from 6.16.210 to 61.16.211 and it worked flawlessly. I nor Droidrzr.com accept any responsibility for any damage to your device if you CHOOSE to use this modification.
WARNING: At least one person has had issues with a Status 7 error on the assert checks to his /preinstall when running the update. He had the same error trying to go to .209 from .181 but was able to revert back. To my knowledge, this is the only failure from the utility and I believe that it would have happened regardless. We are still working on a solution to his issue, but if you have had problems with previous leak installs, you may want to hold off on this one.
UPDATE: The user with the Status 7 error got past it by flashing the .173 /preinstall files and then the .181 /preinstall files prior to applying the update.
If you want to try it, do the following:
*** A full version download has been added below, steps 1 and 2 can be skipped if it is used. I will leave the small download available for a while for folks who already have Matt's Utility and don't need the full file.***
1a. Download and extract (if you don't already have it)
1b. Download the attached DroidRAZRUtility-Modified.zip (this is not the full utility, only the modifications that I made to the .bat file and other files needed that were not already included in the full download)
2. Extract the file to the same folder that Matt's Utility was extracted to. ( I see problems ahead here - this will not overwrite anything that was in Matt's original download)
3. Make a nandroid backup for safety's sake.
4. Take all of the normal precautions and preliminary steps you always do when attempting to modify your phone.
5. Say a little prayer.
6. Download the update file you are going to and copy it to your sdcard.
7. Make sure your phone is in AP Fastboot mode. You can use Option 15 from the Utility to accomplish this if you prefer not to use the manual way.
- If you are updating to .210 you can just run the DroidRAZRUtility-Modified.bat.Make sure your phone is in AP Fastboot mode. You can use Option 15 to accomplish this if you prefer not to use the manual way.
- If you are updating to .211 and beyond, you will need to read the instructions and download the updated script file and associated bootxxx.img file and run the DroidRAZRUtilityFP.bat.
9. From stock recovery select install from external storage, select the update file and wait for it to finish.
10. Once it is finished, wipe cache from stock recovery and reboot, run the utility again and select Option 5 to root 4.0.4. then download superuser from the market and you're back in business with your apps and setup intact.
This has only been tested from a 6.16.209 system going to 6.16.210, but it SHOULD work on any ICS build. You may need to wipe /data if coming from a 4.0.3 build.
When you extract the file the DroidRAZRUtility-Modified.bat file should be in the same folder as Matt's original DroidRAZRUtility.bat. There should now be a sub-folder under /files called /404ROOT and the boot210.img file should be in the /files folder. If these items are not in place the script will not work.
This modification does absolutely nothing that you cannot accomplish with tools already in existence. Namely Matt's Utility, Matt's Unstuck Utility and the new 4.0.4 root script. It just condenses them all into one place and does away with the /data wipe and extra files ( and time associated) that are in Matt's original script.
Disclaimer: I am not a developer, just a tinkerer. Everything contained within this file with the exception of my few script edits are the fruits of other peoples labor. All credit (if any) goes to the respective owners of the original work.
Mods and/or Matt and whoever is responsible for the 4.0.4 root, if this post is out of line, please delete it and accept my apologies.
[edit] fixed path issue in the script and re-uploaded
If your having permission issues downloading this file try .
5.73MB 349 downloads
Full Version - Inclusive of Matt's DroidRAZRUtility 1.6 Final - Link removed due to "I need my Dropbox back".
For as long as the Dropbox bandwidth lasts. All you need to do is download the full version, extract and run the DroidRAZRUtility-Modified.bat file starting at step 3. Running the DroidRAZRUtility.bat file will run Matt's original script as he created it.
- Thanks to (TSON)
I have re-done the script again to hopefully have it ready for the next leak or OTA whichever comes first. Rather than re-upload the whole huge file again at this point, I m just attaching the updated script file. Download it and see the directions for use in
4.57K 144 downloads
