[Guide] GB2ICS: Fastbootable Motorola ICS 6.16.211 For All Gingerbread Users
If you are on any of the above build versions, you have multiple options. You can either go directly up, or RSD back to stock. Either way is fine, but I am going to write this article based on the idea that we are going to start fresh, so no old bootstraps, or other safestrap versions will prevent us from succeeding.
Thanks goes out to Hashcode for creating this SafeStrap Compatbile Build.
Thanks goes out to Matt for DD'ng an ICS Recovery.
Thanks goes out to XBot [ ] for hosting all my required files.
Step 1: Aquire RSD 5.7 Here [ ].
Step 2: Get into Fastboot Mode and choose your destiny!
You have two options: either RSD back to 6.12.173 [ ], or 6.12.181 [ ]
Step 3: Get your root tools!
MotoFail [ ] | Install it and Root your Device
VooDoo OTA Keeper [ ] | Install and Protect your Root
Step 4: Get your leaks!
If you RSD back to 6.12.173, you will need to upgrade to ICS 6.14.75 [ ]
If you RSD back to 6.12.181, you will need to upgrade to ICS 6.14.79 [ ]
Acquire Hashcode's 6.16.211 Custom Stock for SafeStrap 2.0 [ ]
Make sure these are on your SDCARD-EXT
Step 5: Download, Install, and Run pSuedoICS Utility [ ]
Get back into Fastboot Mode. Select option 1, pSuedo Update Recovery to 4.0.4
Reboot your phone into your new ICS Recovery (Vol Up/Down+Power)
Step 6: New ICS Recovery = Easy ICS Installation (we<3Matt)
Install your selected ICS Version that you put on your SDCARD-EXT (Not 6.16.211 yet)
Reboot
Step 7: Run pSuedoICS Utility
Get back into Fastboot Mode. Select option 2, pSuedo Update Kernel to 4.0.4
Reboot your phone and boot into ICS
You now have latest Kernel running on .75/.79 leak
Step 7: Download, Install, and Run SafeStrap ICS 2.0 [ ]
Install SafeStrap 2.0 Recovery, reboot phone, and enter SafeStrap Menu. Backup your Current System, and activate safe mode
Step 8: Install Hashcode's 6.16.211 Custom Stock for SafeStrap 2.0 (Or other DEV's custom ROM based off 211 Leak)
Note: This is the basis of all 6.16.211 developmental ROMs
You maybe able to use another Dev's Custom / Debloat instead of Hashcode's
You now have latest ICS Leak, with latest ICS Kernel
Step 9. Reboot, you now will be using the latest 6.16.211 Leak while remaining Fastbootable.
Profit!
Step 10: Run pSuedoICS Utility (Optional)
Get back into Fastboot Mode. Select option 3, pSuedo Radio Restore ICS2GB Radio Stabilizer
This will downgrade your radio to 6.12.181, the latest stable GB Radio.
This is prevent data drops until we can acquire the latest radio.img
79.64KB 111 downloads
Stock 211 System, 211 Kernel, 211 Recovery, 79 Radio CDMA/LTE
Stock 211 System, 211 Kernel, 211 Recovery, Fully Bloated Stock 3237 Quadrant Score
When the OTA drops, will you still even want it?
