[Guide] Gb2Ics: Fastbootable Motorola Ics For All Gingerbread Users
#21
Posted 17 June 2012 - 01:19 PM
#22
Posted 17 June 2012 - 02:06 PM
#23
Posted 17 June 2012 - 04:21 PM
#24
Posted 17 June 2012 - 04:23 PM
So what is the procedure for returning to .181 and has been done and tested?
Same procedure as first part of OP. RSD back to whatever available system you want.
#25
Posted 17 June 2012 - 05:13 PM
#26
Posted 17 June 2012 - 06:37 PM
#27
Posted 17 June 2012 - 08:17 PM
Just checking, my maxx will be here tomorrow. Since it's on stock software, I can ignore the rsd portions and begin with step 3 right?
Sure can. But you will have to download the corresponding ICS leak that goes with your system.
X
#28
Posted 17 June 2012 - 08:44 PM
I suggest Matts tool for just about everything you need:root, Ota rootkeeper, and can restore when you forget something.
#29
Posted 17 June 2012 - 10:18 PM
#30
Posted 18 June 2012 - 12:30 AM
#31
Posted 18 June 2012 - 03:54 AM
And if so, is there an easy way to remove bootstrap? The old delete logwrapper file methods didn't work last toner I tried...
#32
Posted 18 June 2012 - 05:22 AM
#33
Posted 18 June 2012 - 07:38 AM
#34
Posted 18 June 2012 - 08:39 AM
Is there any way to flash the radio from .211 update? I know the way they update the radios in a patch is different but could you just flash bp.img and lte.img and get new radios? Idk
I would like to know this as well. I am still on the .79 leak and would like to upgrade to .211 using this method. But, my major issue now is data drops. I live in a weak 3g rural area.
#35
Posted 18 June 2012 - 08:45 AM
Working on it.
X
- my2cents likes this
#36
Posted 18 June 2012 - 01:14 PM
I get an "Unfortuantely Safestrap has stopped." when I get to that point.
The superuser is backwards from GB..... allow is on the right instead of the left so if you press the one that you're use to then it will give you that message, at least it did for me.... All you have to do is open superuser and change the setting for safestrap to allow instead of denied and it will work fine.
#37
Posted 18 June 2012 - 02:51 PM
#38
Posted 18 June 2012 - 04:06 PM
#39
Posted 18 June 2012 - 04:15 PM
if i'm running ICS 6.14.79, can I start with step five?
I changed the OP a bit, and now I would start with 5. You need to change your Kernel.
Im still working on the radio portion of things, but for now people can flash .181 radio to use with .211. It's quite solid compared to .75/79.
X
#40
Posted 18 June 2012 - 09:18 PM
- Updated Op with the most current upgrade methods (<3Matt)
- I added a utility I created to help with the install process
- Now have ability to Upgrade Recovery, and Kernel
- Now have ability to downgrade Radio to Stable GB Radio.
Let me know how she runs.
X
