[Guide] Detailed Op On Upgrading To Ics Leak 211 + Rooting
ics gingerbread 181 211 droid razr utility
30 replies to this topic
#21 kellogg
kellogg
  • 114 posts
  • Locationflorida
Posted 21 June 2012 - 04:23 AM
Great right up ....havent been on seen the 1st ics leak so to get this i can go from .75 ics to this 211ics shocked on how meaning leaks that has come out since the last time i was on? the last GB i was on was.173? Did a lil more reading, so would i have to fastboot back to my .173GB then upgrade to .181 to start this process? because i never did a GB .181 i did .75ics from .173GB?
#22 kellogg
kellogg
  • 114 posts
  • Locationflorida
Posted 21 June 2012 - 03:14 PM
1) THE INSTALLATION PROCESS WILL TAKE 10 MIN AND THEN IT WILL SAY INSTALLATION COMPLETE. AT THAT POINT YOU CAN NAVIGATE TO "REBOOT SYSTEM NOW" AND ENJOY ICS!!!!!!!
2) THE INSTALLATION PROCESS WILL TAKE A MINUTE OR TWO AND THEN GIVE A STATUS 7 ERROR MESSAGE
This is completely normal and nothing to worry about. Hold down both Power and BOTH Volume Buttons to shut down phone. go back to STEP 5-3 and repeat all steps. At this point you should get an install complete message and you can enjoy ICS :) (also its not too late to do step 5-1 if you skipped it :D)
EDIT: If you still get a status 7 error or get a status 0 error, repeat this process. It only took me 2 tries but some people report that it took them 4 or 5 tries. After 5 tries if it STILL doesn't work, hop into the chat room :) someone will fix you right up :D
I TAKE NO RESPONSIBILITY IF YOU BRICK YOUR PHONE. YOU ARE DOING THIS AT YOUR OWN RISK!!!!!!!
..................Great right up did everything like said..getting the status0 ERROR install abort at the end have tried 7times? NEED HELP? or any suggestions
Edited by spc_hicks09, 21 June 2012 - 03:30 PM.
#23 sgtguthrie
sgtguthrie
  • 135 posts
  • Twitter:@sgtguthrie1
  • LocationMichigan
Posted 21 June 2012 - 06:29 PM
Great tutorial!!! I followed it and got "Install from SDCARD COMPLETE" on the first try B)
Thanks again!!!
Edit:
Oh ya, your link to the utility to flash recovery worked fine, however the download link to the utility didn't work. I used the pseudoICS tool to do it instead from
and it worked fine. Just FYI...
  • TheG0VERNAT0R likes this
#24 lucid
lucid
  • 6 posts
Posted 21 June 2012 - 11:07 PM
what if even this method is not working for you
i have tried everything!!!!
#25 FaustusPHD
FaustusPHD
Posted 21 June 2012 - 11:15 PM
Folowed the instructions exactly on my droid razr maxx, but now It bricked at the last install and i am not sure what to do. Can anyone help n=me pk=lease?
#26 Guest_BDH_*
Guest_BDH_*
Posted 21 June 2012 - 11:38 PM
Try this:
#27 FaustusPHD
FaustusPHD
Posted 22 June 2012 - 07:06 PM
Need help please. Continue to get status 7 error when installing ics leak. 6 or 7 times. I am a nOOb so any help would be greatly appreciated. I can't even plug my phone back into the computer because it wonnt charge now. Any help would be greatly appreciated.
#28 Senator Palpatine
Senator Palpatine
  • 5 posts
Posted 23 June 2012 - 12:39 AM
Thank you for this, used this in combination with the razr utility pinned thread. Very good and helpful.
#29 TheG0VERNAT0R
TheG0VERNAT0R
  • 6 posts
  • LocationTennessee
  • Current Device(s):Droid Razr XT912, Google Nexus 4
Posted 24 June 2012 - 08:23 PM
Hi everybody. I've had no problems downloading the leak or mattlgroff's utility. But when I try to download the ICS Recovery utility I get
404 Not Found
Is there an alternative location I can download this file. Sorry for the trouble, but thanks for the help. :-)
#30 evo1994
evo1994
Posted 25 June 2012 - 06:01 PM
How do you unzip the utility file?
#31 Alex.Abraham
Alex.Abraham
  • 477 posts
  • Twitter:aabraham123456
  • LocationNew Jersey
Posted 25 June 2012 - 06:30 PM
WinRAR or 7zip (google is your friend :lol: )
Also tagged with one or more of these keywords: ics, gingerbread, 181, 211, droid razr utility
