sure no problem and thanks for your time and effort. Will donate
OP updated. New Eclipse larger battery mod added.
Posted 27 July 2012 - 04:17 PM
Posted 28 July 2012 - 01:53 AM
Hey, I used the drop box link and its still the small 4g. I cleared cache the second time and it still it still was the small ASOP 4g.OP updated. New Eclipse larger battery mod added.
Posted 28 July 2012 - 04:52 AM
Posted 28 July 2012 - 07:27 AM
Posted 28 July 2012 - 10:35 AM
Hey superelaxx, is it possible to make an eclipse mod with the big 4g and toggles like u made for Arctic
Posted 28 July 2012 - 12:44 PM
yes that's what I meant, stock 4g and 3gBeing overtired got the best of me. What I created was a battery mod with larger text. What you were looking for was the stock 4G icon.
I'll do some digging and see if I can change that.
Posted 07 August 2012 - 06:47 PM
Posted 09 August 2012 - 10:30 AM
I would love to lean how you changed these icons so I could do my own 3g 4g icons!Didn't forget about you. Here's the updated mod for Eclipse: original data icons plus solid 1% battery mod.
Posted 09 August 2012 - 10:56 AM
thanks!!Didn't forget about you. Here's the updated mod for Eclipse: original data icons plus solid 1% battery mod.
Posted 09 August 2012 - 12:54 PM
Posted 09 August 2012 - 02:24 PM
Actually, I beleive it was you that had the answer for this. I took the 3G/4G icons from a stock rom and replaced the small ones that were in Eclipse. The trick is making sure you replace all of them
Look into SystemUI/res/drawable-hdpi and you'll find many of the icons you're looking for.
I updated the OP with some basic knowledge on how to change this stuff.
Posted 09 August 2012 - 02:30 PM
Is it JUST drawable-hdpi that the png's need to be replaced? because there is also drawable-sw600dp, drawable-sw600dp-hdpi, drawable-mdpi, and drawable-sw600dp-mdpi. Do the icons need to all be replaced in there as well? Do you just use 7zip to swap the icons?
Posted 09 August 2012 - 02:33 PM
I'm gonna give it a shot. Do you know what those other drawable folders are? I can just push this to my system/app folder, set permissions and reboot right? this doesn't need to be done with flashable zip?Just drawable-hdpi. If you're only swapping images, 7zip will work for you.
Posted 09 August 2012 - 02:37 PM
Posted 09 August 2012 - 02:39 PM
Posted 09 August 2012 - 02:45 PM
nah, didn't work. Booted up with no status bar. ALL I did was replace the png files.
Posted 09 August 2012 - 03:48 PM
What pngs were you replacing? Systemui Can be fussy.
Posted 09 August 2012 - 04:31 PM
Any ones that were data related. Mostly the ones that didn't have lte and all that good stuff. It ends up being like 50 pictures. It's weird how it crashes out the whole UI considering I'm just replacing pictures.
Posted 09 August 2012 - 04:59 PM
A method i use is to drag and drop the replacement images. If you delete, then try to copy over replacements, you may miss one and systemui won't like it
Posted 09 August 2012 - 05:08 PM
