Stuck in AP Fastboot
#41
Posted 19 November 2013 - 04:20 PM
Sent from my SM-N900P using Tapatalk
#42
Posted 19 November 2013 - 04:21 PM
Sent From My DEV X
- johnthehillbilly likes this
Sig by
#44
Posted 19 November 2013 - 04:24 PM
#45
Posted 19 November 2013 - 04:30 PM
Sent From My DEV X
Sig by
#46
Posted 19 November 2013 - 04:55 PM
#47
Posted 21 November 2013 - 04:22 PM
Sent From My DEV X
Sig by
#48
Posted 21 November 2013 - 04:28 PM
#49
Posted 21 November 2013 - 04:29 PM
#50
Posted 22 November 2013 - 03:32 PM
I am stuck in fastest mode and nothing so far has worked. Any ideas?
i made some modifications to matts utility based on a report of steps that fix this issue and need someone to try it out and report back.
there should be no danger in testing, it works fine on a non-borked phone, i tested it myself.
thanks
#51
Posted 30 November 2013 - 06:57 AM
Crud . I knew I forgot something. I'll pm you so I can set up a label.
Sent From My DEV X
just wondering if you got the phone yet, and if the above fix works.
thanks
#52
Posted 30 November 2013 - 08:36 AM
Sent From My DEV X
Sig by
#53
Posted 30 November 2013 - 09:00 AM
#54
Posted 30 November 2013 - 09:08 AM
Sent From My DEV X
Sig by
#55
Posted 30 November 2013 - 09:09 AM
#56
Posted 30 November 2013 - 12:40 PM
lol thanks
50 downloads between here and xda and not one report of it working or not.
you have to have the gpt error, as you do, to test it. i just want to know if it was a waste of time for me or not lol.
#57
Posted 02 December 2013 - 11:27 AM
OK, here is the answer you are looking for - worked like a charm .
Sig by
#58
Posted 02 December 2013 - 12:51 PM
glad you got it fixed
Thanks for reporting back.
#59
Posted 16 January 2014 - 08:07 AM
Nice job fixing, this same thing just happened to me and I'll admit I was carelessly trying to flash back to stock while being rooted with unlocked bootloader and think I flashed the wrong fxz, took an ota and got locked into that bootloader screen. I'll be the first to say I probably don't know enough about programming to be rooting and what not but I can research enough to get by to get a nice ROM running. (Except this time) I called vzw to pretend I took a regular ota and didn't know what happened so they would send me another lol. I'm about to send my bricked one back, are they going to know what happened and charge me 500$ by looking at that bootloader screen?
#60
Posted 16 January 2014 - 02:17 PM
if you can get into fastboot why not try the tool and see if it fixes the issue? just because you flashed the wrong file doesnt automatically mean its hosed.
