Overclocking Ics For Dummys
#21
Posted 23 July 2012 - 10:12 AM
Sent from my DROID RAZR using Xparent SkyBlue Tapatalk 2
#22
Posted 23 July 2012 - 10:44 AM
I tried this and when I go thru smanager to run the 1350 script it says failed, no file or directory found or something.... Even moved the files where they're suppose to be and tried on both my external and internal sd cards.... Help?
try keeping the script in the downloads folder or in its own overclock folder away from the libs. it might help but smanager should have root so it should be able to find the file in system libs. then again smanager isnt a file browser.
did you put fumoto.ko in the correct place? it should go in " System/libs/module" folder when you run the script its looking for that file in a particular place. and if u have trouble placing the file in the folder. use root explorer and mound the folder as r/w so u can paste the file. otherwise itll give u some permission error. Sorry for the confusion someone else could help explain with far more grace then I
ps: this should work on global razrs too.
#23
Posted 23 July 2012 - 11:01 AM
did you put fumoto.ko in the correct place? whem you run the script its looking for that file in a particular place. and if u have trouble placing the file in the folder. use root explorer and mound the folder as r/w so u cant paste the file. otherwise itll give u some permission error. Sorry for the confusion someone else could help explain with far more grace then I
What he said lol. If u have all the files in the correct place use smanager and find ur default and 1350 scripts. If u put them in ur extsd or wherever u put it. Run the default script first. Make sure su is highlighted. Then do the same for 1350 script. U should be good to go then
Sent from my DROID RAZR Overclocked using Xparent SkyBlue Tapatalk 2
#24
Posted 23 July 2012 - 01:53 PM
what did u use to setvesels? i tried qiuck overclock app but it keeps force closingMines overclock to 1375 setvesel is at 58 and running smooth
Sent from my DROID RAZR MAXX Overclocked using Tapatalk 2
#25
Posted 23 July 2012 - 02:01 PM
- milkshed27 likes this
#26
Posted 23 July 2012 - 02:09 PM
#27
Posted 23 July 2012 - 02:12 PM
#28
Posted 23 July 2012 - 02:30 PM
Put the Scripts 1350mhz & Default on your SD and use an Root Explorer to put the fumoto.ko in your System/libs/modules -folder
This makes it sound like fumoto just needs to be in the libs/modules and the scripts can be anywhere, Am I wrong?
#29
Posted 23 July 2012 - 02:38 PM
#30
Posted 23 July 2012 - 02:41 PM
The funmoto goes into system/lib/modules the CPU scripts go to ext-sd but the other 2 zips must be flashed in recovery
#31
Posted 23 July 2012 - 02:42 PM
#32
#33
Posted 23 July 2012 - 02:46 PM
#34
Posted 23 July 2012 - 02:51 PM
#35
Posted 23 July 2012 - 02:52 PM
[Recovery] Razr ClockWorkMod Touch 6.0.1.0 Black Edition [Updated] [07/23/2012]
#36
Posted 23 July 2012 - 02:54 PM
#37
Posted 23 July 2012 - 03:02 PM
Can I just use SS Recovery to flash these? I dont use the safe system all that much due to ROM's not having things needed for work. Thanks for your help so far.
#38
Posted 23 July 2012 - 03:04 PM
#39
Posted 23 July 2012 - 03:35 PM
#40
Posted 23 July 2012 - 03:36 PM
