Overclocking Ics For Dummys
#41 Guest_Bbyland_*
Posted 23 July 2012 - 03:41 PM
Sent from my Droid Razr using Tapatalk 2
#42
Posted 23 July 2012 - 03:44 PM
Sent from my DROID RAZR MAXX Overclocked using Tapatalk 2
#43
Posted 23 July 2012 - 04:00 PM
I have safestrap on my Razr, I dont understand really why I need to uninstall SS to install this.
Can I just use SS Recovery to flash these? I dont use the safe system all that much due to ROM's not having things needed for work. Thanks for your help so far.
You doo not need cwm for this. That is false, ive tested it on bootstrap and im using it with safestrap right now. Just make sure the permissions on the fumoto.ko files is the same as the other files in the libs. And make sure u install the custom gov pack to be able to use it. Make sure ur set on hotplug when running the script. Otberwise u might just get a reboot.
If u dont want to use a custom rom and are on the desafestrap and using the unsafe partition. Just uninstall safestrap and use bootstrap. Its just as easy toinstall but its not as... SAFE
#44
Posted 23 July 2012 - 04:03 PM
Dl the gov files and flash it.
Download the oc pack.
Extraxt it and place fumoto in the libs/nodules folder.
Make sure the permissions are correct.
The 1350 scrip can be placed anywhere.
Run the script and you should now be overclocked...
Done
#45
Posted 23 July 2012 - 04:04 PM
Droid Razr Maxx @ 1.35GHz with PegasusQ governor and sio scheduler
#46
Posted 23 July 2012 - 04:05 PM
CorrectThis makes it sound like fumoto just needs to be in the libs/modules and the scripts can be anywhere, Am I wrong?
#47
Posted 23 July 2012 - 04:10 PM
Are you on stock ota ics?
#48
Posted 23 July 2012 - 04:12 PM
"I tried to flash the zips in recovery and it was giving me a signature verification failed on both of them. Is there something that I missed?
I got the same prob when i tried to flash the fumoto.zip. Then i realized tbat i needed to extract them and manually place The ko file inthe llibs folder. The fumoto zip itself is not flashable and thats ur prob
#49
Posted 23 July 2012 - 04:14 PM
Yes. .211 with updated.214 kernel
#50
Posted 23 July 2012 - 04:40 PM
#51 Guest_Bbyland_*
Posted 23 July 2012 - 05:05 PM
You used bootstrap I trued safestrap it wouldn't flash so maybe the cwm and bootstrap only work
When I installed with ss and smanager it said failed but looky here
#52
Posted 23 July 2012 - 05:07 PM
#53 Guest_Bbyland_*
Posted 23 July 2012 - 05:18 PM
When I tried safestrap it keep saying failed also. Then I got to reading the original forum on xda and found the link for the cwm touch recovery which is really nice
Where in setvsel do I change it to 58? The top slider bar?
#54
Posted 23 July 2012 - 05:36 PM
#55 Guest_Bbyland_*
Posted 23 July 2012 - 05:39 PM
Yes
Noob question but what does this do exactly? Then you suggested as card boost and force 2D?
#56
Posted 23 July 2012 - 05:47 PM
#57
Posted 23 July 2012 - 06:01 PM
#58
Posted 23 July 2012 - 06:10 PM
#59
#60 Guest_Bbyland_*
Posted 23 July 2012 - 06:25 PM
Well done jim. Bested my 6964 so far...
What Rom, governor, vsel are you guys using? I'm assuming this is with noop
