The only supercharger I got to is 8.2 I think
Sent from my DROID RAZR MAXX Overclocked using Tapatalk 2
To get my over clock to work I had to change the svesels to 54
Sent from my .215 leak razr on arctic215 rom do you wanna get cut?
Posted 24 July 2012 - 08:51 AM
Posted 24 July 2012 - 08:56 AM
Posted 24 July 2012 - 08:59 AM
Posted 24 July 2012 - 09:04 AM
Posted 24 July 2012 - 09:06 AM
ohhh, okay I choose "is executable" my problem is that SetVsel keeps on returning the value on 86% even I am setting it to 52%.
Posted 24 July 2012 - 09:32 AM
I downloaded setvsel and have'nt seen a place to change the values. Just the percentages for each vsel to take over at the bottom?? Also, where did you find a 1375 script? I'm trying to find a 1325 script as thats where my phone was stable before. Right now my speeds are all over the place aka no stability, so I need to figure out how to change the vsel or vesel whatever its called? lolI posted links last night for this. U must get setvesel and drop to 58-52 then apply for the over clock to be stable Sent from my DROID RAZR MAXX Overclocked using Tapatalk 2
Posted 24 July 2012 - 09:48 AM
Are clicking apply+quit after settingvesel
Posted 24 July 2012 - 10:24 AM
Posted 24 July 2012 - 10:29 AM
yeah I figured out that there is only 1 scale for our phones. In your screenshot you have your set at 86, I set mine at 53 and it seems to be staying where it should now in set cpu. Should I check apply sd card fix as well? Thanks for your input by the way.See the circle with a lightning bolt slide that
Posted 24 July 2012 - 10:31 AM
Posted 24 July 2012 - 10:35 AM
okay, thanks again. I am loving this speed boost that I had back when gingerbread was still our operating system. I know it is still in its infancy, so hopefully it just gets better from here. On gingerbread my phone preferred 1325 but so far so good. Then again I haven't started playing any games like mass effect infiltrator yet. I think you said your phone is clock thats 1375 correct? Where can I find a script for that as well as 1325? I have the old ones from gingerbread but they don't workI did don't know if there's a difference tho
Posted 24 July 2012 - 10:37 AM
Posted 24 July 2012 - 12:13 PM
Posted 24 July 2012 - 12:31 PM
Posted 25 July 2012 - 05:43 AM
"No trees were killed to send this message, but a large number of electrons were terribly inconvenienced" -- Dr. Neil deGrasse Tyson
Posted 25 July 2012 - 06:18 AM
I noticed this too. I deleted the fumoto.ko file, set setvsel back to defaults, rebooted and so far it's been normal operation again. I can't seem to run 1350 anyway. Just not stable on my device so stock it is I guess. Unless there's a 1300/1325 option that I'm missing.Anyone else having issues where the clock gets stuck at 300 after sleep / power on? The OC ran great, phone felt new agian. After a few hours, however, everytime I turn the phone on, the clock is stuck at 300. Open SetCPU and it shows that it's max 1350 min 300, but I have to change the max to something else, then back to 1350 to get it to stick. Same process after a sleep / power on. Was running the 1350 script at boot, thought that was the issue, so I removed it. Now when I boot without running the OC script, I get stuck at 300/300 with 1200 as the max. Run the script manually and 1350 becomes an option, but same issue...once it goes to sleep it gets locked at 300/300.
Posted 25 July 2012 - 06:21 AM
Posted 25 July 2012 - 06:59 AM
Posted 25 July 2012 - 07:54 AM
Posted 25 July 2012 - 08:19 AM
