(Rom) (Razr Cdma) Aosp Pure Stock Jelly Bean Alpha Stock (10/14) & Kexec (10/18)
Posted 27 September 2012 - 03:40 PM
Stock AOSP Builds
These use the stock Motorola kernel. At this point this is the recommended builds to use due to better battery life and stability.
Kexec AOSP Builds
These will allow custom kernels to be used. At this point I consider Kexec to be more experimental due to the Kexec stuff still being worked on. Camera/camcorder do not work on these builds as of yet and the battery life isn't as good as the stock builds.
Most stuff is working. Camera will work with apps such as Camera 360 from Play Store. Phone calls are not working properly on current build. dhacker29 is aware of the issue and is working on a fix.
As of the 10/7 build location services isn't working.
Wipe data/cache + system + dalvik cache
Install ROM
Install GAPPS
Other Downloads
Posted 27 September 2012 - 03:48 PM
Sent from my XT912 using Xparent Blue Tapatalk 2
Posted 27 September 2012 - 03:51 PM
It's Jelly Bean.Aosp jb or ics?
Posted 27 September 2012 - 03:54 PM
Posted 27 September 2012 - 04:00 PM
Sent from my Droid Razr using Tapatalk 2
Posted 27 September 2012 - 04:48 PM
Ok just recieved phone call and did not show who was calling and normal lockscreen but ringing and ringing and ringing had to restart. Clearing cache and dalvik now!
Ok still does it when called ... phone app comes up like call coming in but black screen and won't let you answer it. Had to turn off to stop ringing but could back outta it after they hung up and FC phone. Any fix?!
Edited by Yeag3r24, 27 September 2012 - 04:59 PM.
Posted 27 September 2012 - 04:53 PM
This is stock JB? Good to flash on the maxx?
Posted 27 September 2012 - 04:54 PM
Give me a break, Give me a break, Break me off a piece of the Kit-Kat Droid
Posted 27 September 2012 - 05:06 PM
Seems too good to be true, haha..
Kind of why the thread was created.
Anyone who flash this have data issues. so far each jb rom i have used losses data on reboot and nothing gets it back.
Try wiping cache in recovery. Are you letting the phone sit for about a minute when it powers up?
Posted 27 September 2012 - 05:07 PM
Yes JB and yes good on my maxx ... just trying to figure out why phone doesn't work
Posted 27 September 2012 - 05:08 PM
DH is aware of this issue and hopefully will fix soon , it is still in early beta ...Running great so far! Feels FLAWLESS.
Posted 27 September 2012 - 05:37 PM
Thanks! Had to do a restore because texting was all messed up then as well and would vibrate while replying to a text. Looking forward to it being more stable!
Posted 27 September 2012 - 05:49 PM
- Yeag3r24 likes this
Posted 27 September 2012 - 06:01 PM
Haha, thanks - got it.
Thanks, I might sit these builds out, though..At least until they're a bit more refined. I've got Arctic hd running and have been happy with this as my daily driver for the past couple of weeks.
Posted 27 September 2012 - 06:04 PM
The CM10 ROMS here on Droidrzr (KOA, Full Throttle, Scapel) are fully functioning for the most part. Bluetooth doesn't work I don't think but other than that everything else works. I'm running KOA and its so far amazing.
Posted 27 September 2012 - 06:13 PM
Bluetooth in terms of music/multimedia stuff works. For phone stuff however it does not.
