Posted 02 October 2012 - 03:15 PM
Basically the touch input from the external display would have to be output through usb to the hd dock as if it were mouse input. I haven't had any luck finding a touch monitor that specifically states that it has this ability. If anybody can reply with link to one or can point me in the right direction I would be very gracious and happy to post pics of my setup once it's complete.
I have razr maxx on 6.16.215, not that this should matter for what I want to accomplish.
Thanks!
Posted 02 October 2012 - 03:49 PM
Let me explain what I want to do so hopefully my question will make more sense. I want to use my razr as a car 'infotainment' center. I would like to hook up my hd dock in my vehicle and have webtop launch on an external display. The problem I have is that i want to use a touch monitor. Does anyone know of a monitor that would work with this setup.
Thanks!
That would likely require a good bit of development. I doubt there is a market for it, so you would have to learn how to setup the communication between the two devices yourself more than likely.
Posted 02 October 2012 - 04:33 PM
Check out xda under galaxy tab 7 and there are some threads with people who made it their car stereo... pretty neat idea I think...
Sent from the cutting edge of my Droid RAZR MAXX
Posted 02 October 2012 - 04:34 PM
Have you thought about just using a USB trackball or something similar instead of the touch screen itself?
Sent from my RAZR MAXX using Tapatalk 2
Posted 03 October 2012 - 06:37 AM
Posted 03 October 2012 - 08:51 AM
I like the trackball idea! I guess I'm confused as to how a touch monitor transfers its input to a PC. I would've thought that it was over USB for certain devices.
I think I read too much into your first post. I was assuming that you wanted to use the "built-in" touchscreen already in your cars head unit. If you are planning on adding a touchscreen you probably can find one that has USB connectivity.
Posted 04 October 2012 - 06:52 AM
Posted 04 October 2012 - 09:31 AM
Also tagged with one or more of these keywords: webtop
