"Let There Be White" Theme
(Current Version 1.0.4)
Hi all, I’d like to introduce you to “Let There Be White!” It is based off the Simplex idea of clean and simple. White with a splash of chrome!
Close up of status bar icons:
I am not responsible for anything that may happen to your device. (…Nothing should happen)
Thanks: – Creator of Simplex Rom. - bootanimation loop background (from GlassRings-Edify). The many different threads I have read to learn how to do this.
THIS IS BASED ON Simplex-V1.3 | Ics4.04 | 10/1/2012 ROM:
Dock icons are from "Tha Krom" for ADW Launcher. If you like them and have ADW Launcher, get the whole set:
What apk's have been themed (some more than others):
- Framework-res
- Browser
- Contacts
- Gmail
- MMS
- Phone
- SystemUI
- Bootanimation – Have a look and see!
- Battery Icon changed. This is a greyscale version off my "Duracell inspired" battery icon. (with 1% battery changes).
- Status Bar Icons.
- Dialer font.
- Lockscreen Clock Font.
- Dock and Lockscreen Icons.
- Default Wallpaper – Can be changed to any wallpaper.
- White text in SMS.
- MANY different icons.
SMS text colors change to white.- Suggestions?
Installation:
(This is asumming you are already on Simplex-V1.3 | Ics4.04 | 10/1/2012)
- LTBWhite_v1.0.4 DOWNLOAD:
- Download and install onto SD Card.
- Reboot into Recovery Mode SafeStrap (I have only tested using SafeStrap v2.11 and above).
- If you want to be safe: Wipe Cache Partition, Wipe Dalvik Cache (In “Advanced”).
- Choose “Install zip from sdcard.”
- Locate “LTBWhite_v1.0.4.zip”
- “Yes – Install LTBWhite_v1.0.4.zip”
- After installation, Reboot, and enjoy!
Default_wallpaper (It may not change upon flash):
Optional Wallpaper and Widget:
Default_wallpaper:
Widget:
This is a Ultimate Custom Clock Widget which has been themed with fonts and colors. Based on a design by CDart at xda-developers, but made from scratch excluding the bezel.
Installation:
- Install UCCW:
- Download ZK-LTBW2.uzip:
- Save to /sdcard/UltimateCustonClockWidget/
- Create widget by selecting appropriate size (4x2) and press "tap to open" when asked.
- Press menu, "Import skins"
- Navigate to /sdcard/UltimateCustonClockWidget/ and select ZK-LTBW2.uzip
- NOTE: Due to transparent space the widget may look "low." To help just change Apex homescreen settings "portrait grid" to 6x4.
- Enjoy!
v1.0.2:
Updated Dialer Font to match lockscreen clock.
Edited more icons.
v1.0.3:
Updated MMS.apk - White text in SMS messaging.
Basic emoticons themed.
Added Carbon Fiber background to status bar pulldown
v1.0.4:
Boot animation updated
Status bar clock font matched to theme font
"Verizon Wireless" on status bar pulldown - removed.
Optional Widget has been updated - Not included in download - See above.
If anyone would like to pull and edit to use things for theming etc, go ahead. If you do post, all I ask is to be added under credits with a link to the page. You do not need to ask.
