Root For Droid Razr M (JellyBean and ICS 4.1.1)
#41
Posted 11 February 2013 - 03:59 AM
#42
Posted 11 February 2013 - 04:26 AM
It should...Hi, id like to know: does it work with razr I with JB 4.1.2 on it?
#43
Posted 11 February 2013 - 07:10 AM
#44
Posted 11 February 2013 - 08:15 AM
It should...
Do you know soneone ho tried it. Because i dont want to brick my phone when i try it.
#45
Posted 11 February 2013 - 10:28 AM
why not use the RAZR I tools?Do you know soneone ho tried it. Because i dont want to brick my phone when i try it.
#46
Posted 11 February 2013 - 10:30 AM
Here is the link to those files.
#47
Posted 11 February 2013 - 12:33 PM
http://www.batakang.com/ftp/?dir=RAZRi
THX for the link but to use the new .zip i have to unlock the bootloader, right? Because motofail wont work on JB 4.1.2., right? ID like to find a way to root without ordering an unlockkey from motorola because i wont lose my waranty. So is there a option to do it without unlocked bootloader on JB?
#48
Posted 11 February 2013 - 07:30 PM
This link is only for the RAZR I.
#49
Posted 18 February 2013 - 08:23 PM
any advice?
#50
Posted 20 February 2013 - 04:07 AM
superuser:
supersu:
#51
Posted 20 February 2013 - 06:08 AM
#52
Posted 20 February 2013 - 06:23 AM
Just purchased a Droid RAZR Maxx HD and it came with version 4.1.1 (version 9.1.41.XT926) already installed. Can I root this version using the Windows link or MAC link listed in this thread?
the droid razr m and droid razr hd are similar, but not sure. worst that could happen is the root attempt would fail.
btw, you'll probably have better luck getting answers to your droid razr hd questions in the droid razr hd forum:
#53
Posted 20 February 2013 - 06:35 AM
Root method for HD [Xt926]
How To Root Your Hd [Xt926]
#54
Posted 26 February 2013 - 07:58 PM
#55
Posted 27 February 2013 - 08:15 PM
It dont matter what method you use... you can always unroot.Is there a way to unroot using this method?
#56
Posted 27 February 2013 - 08:18 PM
Nope. Rsd and sbf files are your unrooting tools.
Sent from my XT907 using Xparent Blue Tapatalk 2
#57
Posted 28 February 2013 - 08:39 AM
actually both the Superuser and the SuperSU have an option to full unroot and you can than delete the app manually...Nope. Rsd and sbf files are your unrooting tools.
#58
Posted 28 February 2013 - 06:32 PM
[*] Motofail2Go: Motorola Android Root Exploit (Windows version)
[*] Tested on Atrix HD, Photon Q, Razr M, and Razr i
[*] is connected via USB.
[*] Waiting for device...
[*] Device found.
[*] Installing fake package...
4339 KB/s (564403 bytes in 0.127s)
pkg: /data/local/tmp/Sudoku.apk
Success
[*] Preparing for exploit...
4082 KB/s (91980 bytes in 0.022s)
4596 KB/s (969701 bytes in 0.206s)
4774 KB/s (1867568 bytes in 0.382s)
4478 KB/s (64208 bytes in 0.014s)
[*] Please trigger a bugreport on your phone by pressing
[*] Volume Up + Power simultaneously. If successful, your device
[*] will vibrate. Make sure this vibration is distinct from the
[*] vibration that occurs when you turn the volume all the way
[*] down. Press enter once you have successfully triggered a
[*] bugreport.
[*] Getting root...
[*] This may take a minute or two.
[-] Exploit failed.
[*] Cleaning up...
Success
Keep getting exploit failed after wiping both data and cache AND I DID DO THE BUG REPORT!
All drivers up to date!
This is the RAZR M and I tried both Superuser and SU. I have 4.1.1 ICS
#59
Posted 28 February 2013 - 06:46 PM
And this is root for Razr M not HD
#60
Posted 28 February 2013 - 06:54 PM
Bing (1)
