[Theme] "Arcade" for Simplex Rom
Simplex Theme Arcade ZK
12 replies to this topic
#1 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 16 November 2012 - 12:27 PM
"Arcade" Theme
(Current Version 1.0.1)
Hi all, let's bring it back to the 1980's and go 8-bit style with "Arcade!"
Sorry about the alarm on the lock screen, forgot to turn it off for the photo shoot :P
Custom boot animation:
I am not responsible for anything that may happen to your device. (…Nothing should happen)
– Creator of Simplex Rom.
- bootanimation tips.
- custom icon help.
- for his various theming tips.
THIS IS BASED ON Simplex-V1.3 | Ics4.04 | 10/1/2012 ROM:
What apk's have been themed (some more than others):
  • Framework-res
  • Browser
  • Contacts
  • Email
  • Gmail
  • MMS
  • Phone
  • SystemUI
Differences to Simplex-V1.3:
  • Boot animation – My creation of an arcade combination.
  • Status Bar Icons.
  • Dialer font.
  • Lock screen Clock Font
  • Dock and Lock screen Icons.
  • Default Wallpaper – Can be changed to any wallpaper.
  • White text in SMS.
  • MANY different icons.
Upcoming Changes:
  • Suggestions?
  • Make lock screen background darker.
  • Make a themed battery icon.
Installation:
(This is assuming you are already on Simplex-V1.3 | Ics4.04 | 10/1/2012)
  • Arcade_v1.0.1 DOWNLOAD:
  • Download and install onto SD Card.
  • Reboot into Recovery Mode SafeStrap (I have only tested using SafeStrap v3.05).
  • If you want to be safe: Wipe Cache, Wipe Dalvik Cache (In “Wipe”).
  • Choose “Install”
  • Locate “Arcade_v1.0.1.zip”
  • "Swipe to Confirm Flash"
  • After installation, Reboot, and enjoy!
Default_wallpaper (It may not change upon flash):
Icon Pack
This is a zip of various icons like the dock icons. Download, unzip and use the icons you want. If using Apex Launcher, long press on the icon, select "Edit", press icon, and locate the icon you want to replace it with. Then press "OK."
Change Log:
(To come)
If anyone would like to pull and edit to use things for theming etc, go ahead. If you do post, all I ask is to be added under credits with a link to the page. You do not need to ask.
  • vtwinbmx and trekkin1707 like this
Donate? Click on signature :)
#2 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Reserved.
#3 Guest_24v_*
Guest_24v_*
Posted 16 November 2012 - 01:26 PM
This is great! I like the old school look of it.
#4 dubsx
dubsx
  • 400 posts
  • Twitter:dubs_x
  • LocationThe OH
Posted 18 November 2012 - 12:22 PM
this is awesome man, great job! very original idea, I love it
#5 usmcamgrimm
usmcamgrimm
    Berserker
  • 958 posts
  • Twitter:@usmcamgrimm
  • LocationMassillon, OH
  • Current Device(s):VZW G3
Posted 18 November 2012 - 01:26 PM
That looks great!
#6 theBonVoyage
theBonVoyage
  • 118 posts
  • LocationCharleston, SC
Posted 19 November 2012 - 10:15 AM
So who wants to port this to Evolution 4.0! :-) I'll do the work if you tell me how!
#7 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 20 November 2012 - 10:46 AM
Have you done any theming work before?
I might be able to port it over, I just don't know when I'll get the time with Thanksgiving and all.
#8 dysfunkshun
dysfunkshun
  • 102 posts
  • LocationLas Vegas
Posted 20 November 2012 - 05:01 PM
I had to flash simplex just to try this theme out! It looks awesome, thank you for your work! My only question would be would it be possible to theme more of the apps, such as chrome and play? Again, thank you for your time and effort!
#9 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 20 November 2012 - 05:04 PM
I'll put the icons up in the OP as a zip file :)
#10 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 20 November 2012 - 05:08 PM
It's up there, help yourself!
#11 dysfunkshun
dysfunkshun
  • 102 posts
  • LocationLas Vegas
Posted 20 November 2012 - 09:12 PM
Damn, talk about quick service!! Thanks again, that is awesome!
#12 theBonVoyage
theBonVoyage
  • 118 posts
Posted 23 November 2012 - 12:01 PM
Never done any themeing before. I have 0 experience buy always wanted to learn.
#13 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
Posted 23 November 2012 - 01:08 PM
There are a lot of threads on here where you can begin to learn how to theme. It isn't too difficult once you get everything set up like apk-multi-tool or apk tool.
My recommendation to being learning is to start with a rom and begin to change the things you want. Google becomes your best friend.
I would give you the files I used but it would provably be easier to look and learn. Ask questions too!
Also tagged with one or more of these keywords: Simplex, Theme, Arcade, ZK
