Posted 11 October 2014 - 11:27 AM
Well, with that RSD photo you put on here, it is failing on the tz because the mr2 version you are attempting to flash is an older version than what you currently have on your device. With the roms you are flashing , you have to be sure you are using ones that are built for your current bootloader, kit Kat or jb depending on which you are on.
sent from my G3
Sig by
