This is battery in place.... power off and AC unplugged.... notice the voltmeter.... this is what is confusing me.... battery shows full charge and putting power to the MOBO.....
sent from my DROID RAZR tapadriving ...
Looks to me like the battery is good, those would be the correct leads.. hmmmm, pounding my head on this one.. Do you hear any noise from either the laptop charger or battery when plugged in? is Anything heating up more than usual??? Was going to say check AMP draw, but it doesn't draw any and wont matter anyway...
Ok here is the list I have of what's been done, or I assume,
1. Does laptop turn on with only battery while AC unplugged? Yes
2. Does laptop turn on without battery with Ac? Yes
3. Does laptop turn on with both battery and AC? Yes
4. 14volts ok? Yes
5. 5v ok? Yes
6. OS ok? Yes
7. Bios Flash done right? Assume yes, re flash wouldn't hurt
8. Clock battery pulled yet for Bios forced reset? No
9. Found Short? Yes
10. Found obvious damage? No
11. checked parts out on wife's laptop? Yes
12. Hammer? Not yet
