bad battery?
41 replies to this topic
#41 johnthehillbilly
Posted 13 December 2012 - 06:57 AM
Just for kicks, Re flash the Bios and manually download it yourself.. Also post the date of the Release..
Also, check link
Decided AGAINST using hammer....LOL
Uninstalled and re-installed OS
Reflashed BIOS from manual dl.... version 310 date 2012.10.30
Cmos battery pulled
Laptop powers on only if AC is supplied
Battery pin tests (black lead chassis grounded)
Pin 1 0 volts
Pin 2 0 volts
Pin 3 0 volts
Pin 4 4.09 volts
Pin 5 0 volts
Pin 6 0 volts
Pin 7 0 volts
Pin 8 15.06 volts
Pin 9 15.06 volts
Black lead battery grounded (pin 1)
All pin voltages the same as above (expected)
Rules out bad ground...
Repaired broken insulation on wifi lead(found earlier)
Tried identical battery (thanx the the geek squad in warrenton, MO) ... still no battery recognized
Board traces in charging circuit appear ok...
Visual inspection of capacitors appears ok
My conclusion..... (without de soldering components)
Bad diode on charging circuit..... which would explain the slight fluctuations in voltages from yesterday to today.......
More than likely caused by direct short of earlier mentioned wire on WIFI card.....
Repair options..... replace all diodes (in circuit) 6 at 75 cents each.... or replace MOBO at about $150 ..... i think its a no brainer.... LOL
Thank you everyone for all your help on this issue.... it is greatly appreciated!!!
  • Torin_93 likes this
#42 satman80
satman80
    Gny. Sgt. Hartman
  • 3,159 posts
  • LocationPluto
Posted 13 December 2012 - 07:34 AM
Topic locked per request johnthehillbilly. Solved.
Site Rules and Guidelines
