Flying Sunset Theme
(Current Theme Version 1.0.4)
Hi all,
Here is a yellow theme based on the a sunset while flying.
I am not responsible for anything that may happen to your device (Nothing should happen...)
What apk's have been themed (some more than others):
- Framework-res
- Browser
- Contacts
- Camera
- Gmail
- MMS
- Phone
- SystemUI
- Status Bar icons: Yellow.
- Dialer number colors.
- Lockscreen Clock Font.
- Dock and Lockscreen Icons.
- Default Wallpaper – Can be changed to any wallpaper.
- MANY different icons.
Installation:
(This is assuming you are already on Aviator ROM: . If you are, continue on.)
- DOWNLOAD THEME:
- Download and install onto SD Card.
- Reboot into Recovery Mode SafeStrap (I have only tested using SafeStrap v3.xx, but it should also work with 2.11).
- If you want to be safe: Wipe Cache, Wipe Dalvik Cache (In “Wipe”).
- Choose “Install.”
- Locate “Flying Sunset” file.
- Swipe to Confirm Flash.
- After installation, Reboot, and enjoy!
- To uninstall the theme, download this file and flash using the above instructions.
Utility
This is a basic utility for switching between battery icons. I have also included an option for simple battery and NO quicksetting toggles.Download: Work in progress
Instructions:
- Unzip file and run Aviator Utility.bat.
- Follow the onscreen instructions.
- NOTE: You may need to reboot for a second time if SystemUI force closes on boot. You should only need to do this once.
A custom boot animation when I come up with a good idea
If anyone would like to pull and edit to use things for theming etc, go ahead. If you do post, all I ask is to be added under thanks/credits. You do not need to ask.
