Anyone experiencing this issue. I have my ringtones in a folder called ringtones on my SDCard. For some reason when I associate a ringtone to a contact it is not holding.
Are you experiencing this or have ideas for me to try?
Wondering if I need to put the ringtones on the phone and not the sdcard.
Thank you
4 replies to this topic
Posted 21 February 2012 - 11:32 AM
Posted 21 February 2012 - 11:55 AM
I'm having a problem with system notifications and phone ringtone sticking. Every now and again I have to reassign them after they revert back to default.
Posted 22 February 2012 - 06:12 PM
I am as well, and it's completely random. Im not running any roms, just stock rooted.
Posted 23 February 2012 - 07:45 AM
If they are on the SD card, move them to phone storage. Every time you connect the phone to your computer it removes the phone's access to the SD card, causing the phone to go back to default ringtones.
Posted 23 February 2012 - 10:14 AM
Create a folder (if its not already there) on your internal card called media, inside that audio, then inside that make two called ringtones and notifications and put the tones in their respective folders. They will now show up along with the ones that come on your phone in the stock ringtone menus.
No one cares where this was sent from
:-D :-D
Also tagged with one or more of these keywords: ringtone, contacts
