As the title implies, is it possible to root without first restoring back to ICS 4.0.4? Just got my wife a Razr HD that came out of the box already on JB 4.1.1.
Possible to root w/o going back to 4.0.4 first?
Sam Abuelsamid
, Mar 09 2013 02:32 PM
root
5 replies to this topic
Posted 09 March 2013 - 02:32 PM
Posted 11 March 2013 - 07:05 PM
not yet and probably not going to be at least for a long while
Do it now you may not be able to later
Posted 12 March 2013 - 05:40 PM
Just do it. It's extremely easy. Read up before you do any big step, and if you screw it up it's your fault. It's a deceptively simple process, and it's definitely worth it.
Posted 13 March 2013 - 01:31 AM
Thanks, I knew it was easy having previously reflashed my own MAXX HD. I was just hoping to saving a bit of time and some steps. I actually did the restore to 4.0.4 a couple of hours after the OP and subsequently rooted and then did the OTA back to 4.1.1.
- PantherHeel93 likes this
Posted 13 March 2013 - 04:51 PM
Good man!
Posted 13 March 2013 - 05:54 PM
here is a good how to
Also tagged with one or more of these keywords: root
