@razrmaxx if your phone is unlocked with custom recover the easiest way to flash this ROM is just to ROM section for the 4.1.2 dst ROM and flash the 4.1.2 boot.IMG zip. Then mount system and flash the deodexed ROM zip in twrp or cwm. That would be your best best without going through the hassle of RSd lite
@razrmaxx what @tjnaps27 said is your best bet. I've been following this for awhile now. I am going to give you some props (a good thing) for not giving up. Most would have run an hid once they make you do the research. These folks are helping you. it may not feel like it but they are teaching you how to do things that once you get it you'll never forget.
I see that RSD is a hurdle that you want / must tackle. You appear to not want to give up. This is good! A couple of items I haven't seen mentioned yet:
Are you using a Motorola factory cable? wrong cables sometimes work sometimes don't.
Have you tried a different USB port on your PC? It's strongly suggested to use one on the back of the PC.
Sometimes either of those will work for some instances but not for others.
Have you powered off your phone, booted into bootloader then connected it to the PC and run RSD?
Have you tried running RSD as Administrator?
Like I said once you tackle it you win.
Hopefully I didn't step on anyone's toes or hurt their feelings.
