Recovery /bootstrap For Ics 4-8-12
#1 Guest_DirtyDroidX_*
Posted 08 April 2012 - 08:05 AM
I have tested this out and it works great. The only thing that does not work is, mounting USB, other then that nandroids, advanced restore, and flashing are all functioning properly.
Install the apk as any other app.
++IF YOU GET A ERROR WHILE USING A BACK UP. DELETE THE SU BACKUP FROM ROOTKEEPER++
*****************************************As always DroidRazr, myself or anyone other then yourself, is NOT responsible for anything that may happen to your phone. *****************************************
- mugsy77, mattlgroff, jtelander and 4 others like this
Posted 08 April 2012 - 08:14 AM
Posted 08 April 2012 - 08:35 AM
Sent from my DROID RAZR using Tapatalk 2 Beta-6
#4 Guest_DirtyDroidX_*
Posted 08 April 2012 - 10:21 AM
Posted 08 April 2012 - 10:30 AM
Posted 08 April 2012 - 10:55 AM
*****************************************As always DroidRazr, myself or anyone other then yourself, is responsible for anything that may happen to your phone. *****************************************
You may want to amend that disclaimer to IS NOT RESPONSIBLE
- lownslow200sx, pdumont1 and joeyx2 like this
Posted 08 April 2012 - 11:17 AM
Is there a safestrap?
I guess I got lucky. I installed safe strap and didnt have a problem.
Posted 08 April 2012 - 11:18 AM
LOL! Nice catch.
#9 Guest_BDH_*
Posted 08 April 2012 - 11:38 AM
EDIT: Advanced Restore, Restoring system always fails every single time.
#10 Guest_DirtyDroidX_*
Posted 08 April 2012 - 01:01 PM
- NattyBee likes this
Posted 08 April 2012 - 02:03 PM
Posted 08 April 2012 - 02:08 PM
Sent from my DROID RAZR using Tapatalk 2 Beta-5
rm: can't remove '/system/su-backup': Operation not permitted
rm: can't remove '.' or '..'
can't remove old file system/su-backup: Operation not permitted
- saantomoh likes this
Posted 08 April 2012 - 04:01 PM
The restore fails when it encounters "su backup".
Either install a terminal emulator on your phone or use the adb shell.
Type "su" and hit enter. If you're using a terminal emulator on your phone, a superuser access notification will pop up. Allow it.
Then type the following:
chattr -i /system/su-backup
and hit enter. Try restoring again.
I'm not completely sure if that's the problem, but it's worth trying.
EDIT: You might not even need to use su for that. But whatever.
Posted 08 April 2012 - 06:28 PM
Posted 08 April 2012 - 06:34 PM
sh-3.2$ su
sh-3.2# chattr -i /system/su-backup
root@(unknown):/# /system/su-backup: 1: Syntax error: word unexpected (expecting ")")
root@(unknown):/# NV]du000: not found
root@(unknown):/# /system/su-backup: 2: Syntax error: "(" unexpected
root@(unknown):/# /system/su-backup: 2: Syntax error: "|" unexpected
root@(unknown):/# /system/su-backup: 2: Syntax error: word unexpected (expecting ")")
root@(unknown):/# on_codecom.noshufou.android.su.RESPONDUsage:: not found
root@(unknown):/# ]: not found
root@(unknown):/# /system/su-backup: 4: Syntax error: "(" unexpected
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/# : not found
root@(unknown):/# root@(unknown):/# root@(unknown):/# root@(unknown):/# /system/su-backup: 18: Syntax error: word unexpected (expecting ")")
root@(unknown):/# sh-3.2#
Make sire your su binary is up to date
#17 Guest_DirtyDroidX_*
Posted 08 April 2012 - 06:48 PM
Anyone successfully restore a nandroid with this?
Yes
#18 Guest_DirtyDroidX_*
Posted 08 April 2012 - 07:00 PM
sh-3.2$ export PATH=/data/local/bin:$PATH
sh-3.2$ su
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
root@(unknown):/#
: not found
also did u mount the system cause if you did not, in recovery, ur not accessing the actual system partisan
#19 Guest_BDH_*
Posted 08 April 2012 - 07:01 PM
#20 Guest_DirtyDroidX_*
Posted 08 April 2012 - 07:03 PM
