Try mounting the system.
Thanks! I'll try that later and let you know what happens. I understand that you didn't make the recovery or anything but it's extremely hard to get ahold of DHacker lol.
Posted 08 April 2012 - 07:16 PM
Posted 08 April 2012 - 08:27 PM
Posted 08 April 2012 - 09:13 PM
Posted 08 April 2012 - 09:49 PM
Going to Advanced Restore, then restoring system does not work for me. No nand restore option works on my phone, any suggestions?
Posted 08 April 2012 - 10:33 PM
Posted 08 April 2012 - 10:37 PM
That was it! Deleting Voodoo backup fixed the restore problem. Thank you.
Posted 08 April 2012 - 10:44 PM
You're welcome, glad that did the trick!
Posted 08 April 2012 - 10:49 PM
Are you talking about deleting the su-backup file in /system? Everytime I mount as rw i get "delete failed."
Posted 08 April 2012 - 11:12 PM
No. Just open up the app. If you have already backed up root, there are 2 options. Just click the one that says Delete su backup and you'll be good to go!
Posted 09 April 2012 - 01:11 AM
Posted this in another thread as well, but here it is again.
Question for you: Do you use Voodoo to protect your root? If so, before booting into recovery & attempting to restore your nandroid backup, open Voodoo and delete your backup of root. This has caused issues for me previously! Let me know if this works for you
Posted 09 April 2012 - 05:14 AM
Good info! This should be added to the OP
Posted 09 April 2012 - 12:37 PM
Posted 09 April 2012 - 01:48 PM
Posted 11 April 2012 - 11:38 AM
Posted 11 April 2012 - 01:33 PM
I have that problem too.hmm...i'm havin problems getting into ics bootstrap when i hit the button it does nothing but i cant but when i hit reboot ics recovery it boots then.i have full root and when i go into su binary it says manifest fail..any suggestions
Posted 11 April 2012 - 01:37 PM
Posted 11 April 2012 - 03:46 PM
Do you have Busybox installed? Pressing the top button in the app just installs the recovery. Pressing the "reboot ics recovery" button will reboot you into recovery. As long as you can reboot into recovery you should be good. Also make sure you delete the su-backup file in /system before you try to restore any nand backups.
Posted 11 April 2012 - 04:29 PM
Posted 11 April 2012 - 04:38 PM
Hey, PillClinton, that definitely worked for me & I've been wondering why I couldn't restore System fm my nandroid backup for quite a while.
Excellent catch on this, you've enhanced my ability to do mods & feel safe doing so; now I don't have to go back to my pc rescue my Razr Maxx using Matt's util. I can restore fm the nandroid b/u on my device!
Hearty thanks! seeker
Posted 11 April 2012 - 04:58 PM
yo good lookin on that spc i do not have busybox installed and i did a nandroid back up before deleteing the su back up file should i re do the back up w/the delete of su?
