Cool. Well thanks for the lesson manYeah, I'll probably add more frequencies. Uses more battery. Most of the time there is no visible increase in smoothness.
[KERNEL] Code Kernel 7/24/13
#41
Posted 06 May 2013 - 10:06 PM
#42
Posted 07 May 2013 - 02:23 AM
#43
Posted 07 May 2013 - 04:50 AM
Thanks for the kernal, flashing now.
#44
Posted 07 May 2013 - 06:19 AM
Works on xt926 and xt925 ?
Envoyé depuis mon XT925 avec Tapatalk
I know it works for XT926. XT925 you could try.
Sent from my Nexus 4 using Tapatalk 2
#45
Posted 07 May 2013 - 06:50 AM
Installing now. Thanks (hopefully lol) Byte!
#46
Posted 07 May 2013 - 06:55 AM
can i install this on my cm10.1? epinters build it has what appears to be epinters version of this kernel already
#47
Posted 07 May 2013 - 07:06 AM
Yes, you can. This kernel is an enhanced version of what he and some others did.
#48
Posted 07 May 2013 - 07:45 AM
- trikotret and JJT211 like this
#49
Posted 07 May 2013 - 07:59 AM
OK i will do it
I must flash the kernel before or after the rom ?
#50
Posted 07 May 2013 - 08:00 AM
OK i will do it
After the ROM.
#51
Posted 07 May 2013 - 08:03 AM
I'm working on getting CM10.1 installed so I may get around to trying this kernel in the next couple days.
#52
Posted 07 May 2013 - 08:40 AM
This kernel has more lag than the stock kernel on dt codex Rom. Flashed back stock kernel
#53
Posted 07 May 2013 - 08:45 AM
You're the only one lol
I bet you ran it for 5 minutes after first boot, and didn't reboot a 2nd time after first boot.
Custom firmware isn't magical, it has to settle in and build caches.
#54
Posted 07 May 2013 - 09:47 AM
Reboot, get the red moto logo then black screen, have to hard reset to get to recovery. Install stock kernel, boots fine. Weird
#55
Posted 07 May 2013 - 09:51 AM
Installed, won't boot on my phone running RageHD 1.1.
Rage HD is a Blur based ROM. I may look into adding support Blur of possible.
- dimqs153 likes this
#56
Posted 07 May 2013 - 10:35 AM
- BytecodeMe likes this
#57
Posted 07 May 2013 - 10:43 AM
Seems tout work fine on xt925<br /><br /><br />Envoyé depuis mon XT925 avec Tapatalk<br /><br />
It should also work on The Razr M and every other Moto 8960 phone.
#58
Posted 07 May 2013 - 11:04 AM
Lol only one huh? Just sharing my experience which comes from a long history of experience with a lot of devices. I ran the kernel since it was posted for the last two days. Tried various options and settings and experienced more lag than the kernel dt included in his rom. That's MY experience that I'm sharing on the forum. I'm not bitc$%#g or attacking or even asking for your feedback....
#59
Posted 07 May 2013 - 03:03 PM
So far I have:
Compatibility with XZ compression added to kernel
Updates to memory management
Disabled frame_pointer for faster kernel
-03 compile optimizations
Optimize memcopy and string
Optimize TCP with a really cool patch I found
Optimize AES and SHA1 encryption
Testers feedback has been positive so far.
- chdwrk and shane1 like this
#60
Posted 07 May 2013 - 04:09 PM
cant wait until u make for blur base...most aosp rom doesnt support GSM network on XT986
