[Mod]Droid Razr Ics Leak - Deodexer
#61
Posted 23 April 2012 - 08:28 PM
#62
Posted 23 April 2012 - 09:13 PM
Question for everyone if on .173 ...was on ICS leak recently which is when I used ICS boostrap to do a backup...full backup I believe ...I believe including web top. If I install and boot into recovery...whip everything and then restore the backup of ICS....will that work? Radios and all? Or am i looking at a full run back up to ICS with all the leaks and what not? Sorry for hijacking but I just got bounced back to .173 during this install for some reason.
Sorry but I don't think that is possible...the radio/kernal can only be changed by RSD Fastboot files or Bootloader bypass (which doesn't work for CDMA Razrs). If all you did was flash this zip then there is NO WAY you could have gone back to .173 Also, nand backups I believe only backup system and data, nothing else. I may be wrong though, since I usually do not backup, hehe.
#63
Posted 24 April 2012 - 07:26 AM
#64
Posted 24 April 2012 - 07:59 AM
+1... trust me I wish there were an easier way... but for right now you'll have to start from scratch. I know this from personal experience! LolYou cant make progress without breaking things sometimes ;-)
+1 True that
- fastfoodfred likes this
#65
Posted 24 April 2012 - 10:42 PM
#66 Guest_BDH_*
Posted 24 April 2012 - 11:53 PM
Any 1% mods for deodex out yet?
Nope
#67
Posted 25 April 2012 - 06:00 AM
One issue, Webtop wasn't in the installl package, was there a particular reason?
It was one of the few things I really liked (besides Smart Actions..) If anyone can pull the .apk and dropbox it to me that would be great!
#68
Posted 25 April 2012 - 06:31 AM
#69
Posted 25 April 2012 - 06:32 AM
#70
Posted 25 April 2012 - 06:46 AM
Webtop is option 1. I forgot what two is, and 3 is mirror mode. Webtop Makes your phone look like a trackpad, gives you soft buttons and allows you to change the resolution as well as running apps in phone mode or webtop mode. It rocks... Was playing Shadowgun at 1920*1080 on a 55" LED Samsung. The app isn't on my phone anymore.
Regardless of if it's in the install or not, I lost it so would greatly appreciate it if someone could help me out :-)
#71
Posted 25 April 2012 - 07:05 AM
Edit: is it called welcomewebtop.apk? I have it and will send you it. PM me your email and I will attach it.
#72
Posted 25 April 2012 - 07:45 AM
#73 Guest_droidpcguru_*
Posted 25 April 2012 - 08:29 AM
#74
Posted 25 April 2012 - 11:13 AM
- leviwg likes this
#75
Posted 25 April 2012 - 02:25 PM
#76
Posted 25 April 2012 - 04:38 PM
#77
Posted 25 April 2012 - 06:40 PM
#78
Posted 25 April 2012 - 07:12 PM
Crap.. I'm low on time.. Wish P3Droid would build us an All in one Update.zip to the ICS leak...lolThanks all for the info. Fyi I didn't flash this zip. It was a general question..... I miss the leak...so I am going back tonight!
Simply Amazing ...
Essentially Stunning,
Motorola Droid Razr---->
Tapped via Red Xparent Pro>:-!
#79
Posted 26 April 2012 - 07:33 AM
#80
Posted 26 April 2012 - 02:22 PM
